Multiple questions 6C
daydotz
Post by daydotz »
Maybe I should have done thread with all my questions lol
Can anyone with the new shape polo tell me if the drivers mfd shows trip time & you can change the digital speed between mph & kph
I'm sure I read the new polo was going to feature adaptive dampers & led lights I doubt anyone knows when these will arrive :(
Has anyone got the semi rigid does it fit the 6c ?
I can't find mirror link available to spec has it become standard ? Is it any good
My old polo I had separate cables for the mmi for USB & iphone has this change to just a USB socket you just plug you iphone lead into ?
Does anyone know if voice activation can be activated with VCDS instead of paying vw for it
Steve9413
Drives: Polo BlueGT
Post by Steve9413 »
I can answer I few
The display shows
Speed,mpg,fuel range,time traveling. also within the stereo it has the think blue feature which can tell you average mpg from last fuel and mpg from start.
I don't think you can change the speed from mph to kph.
Mirror link is not longer available.
There is a USB socket an auxiliary socket it also has a SD slot and cd unit in the glovebox.
Within the audio unit you can change things such as how many doors unlock when you unlock the car, how long the coming home and leaving home lights last and loads more things like that.
Where I've picked the lights and sights pack it means it gives me LED number plate bulbs.
That's all I can input that I can think of at the moment :P
daydotz
Post by daydotz »
