Rattles when cold..
- CrypticG
- Drives: 1.2 TSI SEL (6C)
Rattles when cold..
Hi guys,
Just a small niggle that is annoying. Basically, whenever i am driving over almost all roads, i have a low frequency rattle/creaking coming from my drivers side and passenger side front doors (3-door model). It is coming from the top of the plastic door panel and is mainly audible when the interior of the car is cold. It also occurs when the engine is in high gear with low revs.
Just wondering if anyone has any ideas, experience or knowledge on how to stop the plastic trim on a door from rattling? Preferably without having to take the door apart. Ive been to the dealer with it, when it was in for a software update, but they basically said monitor it and see if it gets worse, but its already worse enough for me! lol :x thanks in advance!
Picture of the area below:
Re: Rattles when cold..
Could be the door pull cable rattling against the door card inside
- CrypticG
Sorry mate, what is that? How could i fix it?alexperkins wrote:Could be the door pull cable rattling against the door card inside
Theres a cable between the door handle and the door lock that runs along the inside of the door card
Its a case of removing the door card, wrapping the cable in bubblewrap (or similar) then putting it back on
- CrypticG
Thank you, sounds a big job bloody hell. Im not great at messing with cars. Might have to pester the dealer.
Its not particularly difficult, though removing the doorcard isnt pleasant lol
- CrypticG
yeah, ive watched a few videos, in particular the removal of an Audi A1 panel and that has some tricky bits
- Drives: 2019 Seat Ibiza 1.0 TSI Xcellence Lux
If it's still on warranty, then take it to the dealer. It shouldn't be rattling.
- CrypticG
Rattles when cold..
It is kind of a really quiet creaking sound to be honest. It sounds like it is coming from the plastic trim though - and when I pull the door handle it seems to stop..? Opening the window disrupts it but then it will start again. It's not a major issue just something that is annoying. It is intermittent as well, sometimes it is present - other times it isn't..
That definately sounds like the door handle cable
- CrypticG
Rattles when cold..
Thanks Alex. I think I am going to send it back in for a fix. No point me messing around when it's under warranty. What should I ask for? To have the door handle pull cables wrapped? Or have the door padded with foam?
I would just ask them to investigate the rattle, and potentially fit sound deadening material where necessary, and that you think it could be the door pull cable
- CrypticG
great, thank you
