My 2008 1.4Tdi has been in bits a few times over the last few months and I've had to remove the intake pipe between the intercooler and the engine. I managed to lose the clip that retains the pipe at the engine end, so ordered a new one, and also a new rubber o ring as the old one was slightly damaged. Ever since, I've had a whistle from this pipe on every gear change. It's very irritating and I want to cure it. I've taken the joint apart a couple of times, but can never properly solve the problem.
Does anyone have a parts drawing of this assembly? Maybe there is another seal I'm missing?
Sounds like a knackered clutch release bearing at the moment! I know it's not that as I just fitted a new one!
