Climaticciclo wrote:ClimaticUgabista wrote: - The climatic error could never erase, back forever, but I do not know what it is because the climatic seems to work well.
- The errors of navigation seems to be the antenna, loose connection maybe.
- The telephone will not know why, the microphone seems to me well connected.
Try making an auto scan with the engine running and first speed fan switch.
Antenna
You must have an aftermarket antenna installed.
Telephone
I think the problem is the wiring. You have to have one like this.
Be configured with SDS.
http://www.carsystems.pl/bluetooth-wiri ... id165.html
The coding unit telephone is correct.
Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
Part No SW: 6R0 820 045 E HW: 6R0 820 045 E
Component: Climatic 24 0600
Revision: 00 10 24
VCID: 306FF64B63D6889E243-8065
1 Fault Found:
16372 - Control Module; Unspecified Internal Error
014 - Defective
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 31090 km
Time Indication: 0
Date: 2013.14.04
Time: 21:04:20
Same?
Antenna:
The antenna is the source I have is this adapter, you can be here?
http://www.aliexpress.com/item/Antenne- ... 61436.html
Telephone:
I have these cables: http://www.aliexpress.com/item/Original ... 73702.html
No good? Or do not give this bluetooth module but may give another?
This bluetooth module is a friend of mine who had a VW Passat which sold and was working well there, lent me to see what allowed in my car, do not know if more can I have another basic or not the same features on my car.
Thanks.
