Anyone got a guide or any tips on how to install the screen mounted dab antenna?
Sent from my iPhone!
DAB antenna.
DAB antenna.
Would be good to see how it handles the signal? Ive been told to stay away
Re: DAB antenna.
Iv got a film DAB ariel fitted on my windscreen. Piece of cake to fit it. I pulled the cover off the side of the left hand side of the dashboard, in the door shut area if that makes sense, and just ran cable down back of dash from there to my stereo. then rest is behind the A pillar
DAB antenna.
How's the signal from the aerial you have fitted?
Re: DAB antenna.
not had a single issue. Happily listening to Kiss fm for past few weeks with no drop out. Just a autoleads antenna that you can pick up in any halfords store with a pioneer dab unit upfront. Hardest part fitting it was removing the door rubber running up the A pillar
