BlueGT Tickover
Rik762
- Drives: 2017 Polo GTI DSG
BlueGT Tickover
Has anyone noticed a variation of the tickover speed with the BlueGT ( or any other Polo ) ? Mine seems to be one of two distinct speeds. Half the time it will be 1000 rpm whilst the rest of the time it will drop to around 700 rpm.
Has anyone else noticed anything similar.
Advice from the dealer was to 'watch it'. Well, I was doing and still am.
- Mart!n-GTI-DK
- Platinum Member
- Drives: '14 Polo BlueGT
Re: BlueGT Tickover
Mine allways idles at 700 rpm...
TheFrog
- Drives: 2015 Blue GT
Re: BlueGT Tickover
My tickover is stable, but I have had cars in the past that wobble a bit. Usually due to electrical things kicking in, like A/C, heated seats, etc.
Rik762
Re: BlueGT Tickover
Is yours stable at 700rpm Mr Frog?
TheFrog
Re: BlueGT Tickover
Yes, approx. 700rpm. Mine is a manual, though; maybe DSG is different??Rik762 wrote:Is yours stable at 700rpm Mr Frog?
Rik762
Re: BlueGT Tickover
Mine will be 700 one day and 1000 another. I can find to reason as I cannot affect it by switching electrical loads on / off or by driving methods. Most strange.
gti-joe
- Drives: 6c Polo Blue GT
Re: BlueGT Tickover
My Blue GT is the same, and like yourself not a clue why.Rik762 wrote:Mine will be 700 one day and 1000 another. I can find to reason as I cannot affect it by switching electrical loads on / off or by driving methods. Most strange.
lancslad1985
Re: BlueGT Tickover
Mine is also 700rpm, but I also have a manual. I may be getting a dsg for 24 hours tomorrow whilst mine is in, if so i will let you know.
Malcolm Scott
- Drives: 2010 (60) 1.2 SEL TSI
Re: BlueGT Tickover
I believe that if the onboard diagnostics detect a low battery voltage (eg by the battery being partially discharged or having an increased electrical load), the tickover is speeded up to give the battery an extra boost.
Re: BlueGT Tickover
^this is the answer. My car does it occasionally when the battery state of charge is low (VCDS tweak to show this)
gti-joe
Re: BlueGT Tickover
Makes sense, cheers for that guys.
Doc_House
- Drives: 2015 VW Polo SE and 1972 GT Beetle
Re: BlueGT Tickover
Old 1.2 TSi did this frequently would sit at 900rpm and then drop to 600rpm when it was warmed up. New one doesn't seem to do it
ORiOn
- Drives: Polo BlueGT / Audi S5
Re: BlueGT Tickover
Normally it does that only when you star-up the car... It's to recirculate the oil faster, and some times when it's too hot or too cold, it will be in higher rpm's to...
Any car does this...
