Installation auto dimming mirror + BCM connector
Hi all,
I'm planning on retro-fitting the auto dimming the mirror on a 'normal' windshield. A foto report will follow this weekend.
I bought this one:
http://www.aliexpress.com/item/OEM-Orig ... 82272.html
The guide I'll be using is ciclo's guide for the wire fitting.
One question:
The set comes without connectors to the BCM.
The wiring is not so difficult, T6/3 to T73b/48 (manual transmission reverse signal) and T3/3 to T73b/24 (LIN bus), both BCM white.
Does anyone know what connectors to use for this?
Thanks!
Re: Installation auto dimming mirror + BCM connector
click :)
MQS - Micro Quadlok System - 0,63mm
000 979 009 E
http://www.a4-freunde.com/showwiki.php? ... zu+gehoert
If I'm not mistaken I sent you one or two of those.
Awesome, thanks man. I'll report back with a nice foto report of the result (or failure)
Danilugomk5
Drives: Polo 6r
Post by Danilugomk5 »
excelente me lo apunto saludo
gracias
Danilugomk5
Drives: Polo 6r
Estaría bien hacer un brico del montaje, ya lo isiste iichel?
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
es-polos.net :mrgreen:
So, the result!
Dimming mirror works
Light sensor still has to be connected to the BCM
More detailed report tomorrow :)
I'm sorry Danilugomk5, no hablo Espanol bien.
Now it's girlfriend time...
Gannu
Drives: 6R 1.6 TDI 105 PS
Post by Gannu »
iichel, how hard was it to take off the stock mirror clamp which was glued to the windshield? What chemical/solution did you use to take it off the windshield?
Excellent iichel! Good job, look forward to see that report.
THE Rosa-line increased its value and driving safety. Coming soon will do it in comfort...Image
Mart!n-GTI-DK wrote:es-polos.net :mrgreen:
You're absolutely right. Hopefully this will not happen again..., never again. :lol:
Please find the report here :)
http://www.uk-polos.net/view ... 95#p492795
I haven't made photos of wiring process, sorry. I think the most important part is the sensor retrofit
alexperkins
Site Admin
Post by alexperkins »
You'll really want to move to P1200 wet and then P2000 wet ultimately, then use a glass polish to smooth the edges and give a good clear finish if you want to be able to use the rain sensor
Danilugomk5
Drives: Polo 6r
iichel wrote:So, the result!
iichel thank you eventhough you wrote in Spanish sorry for doing what I did not realize, I stay perfect.
alexperkins wrote:You'll really want to move to P1200 wet and then P2000 wet ultimately, then use a glass polish to smooth the edges and give a good clear finish if you want to be able to use the rain sensor
I tried it with a bottle of water and it was responding to the water. Pretty much like OEM :P
No but you might have a point. I'll order some P1200 and P2000 and see if I can get it a bit better and report results.
alexperkins
Site Admin
Nice :) Its all about the finish haha
Brasso is good for smoothing out the scratches once they are fine enough
