Polo 6C Subwoofer Install Done (DSP added)
TheFrog
Drives: 2015 Blue GT
Re: Polo 6C Subwoofer Install Done (DSP added)
Post by TheFrog »
rsmagee wrote:It's super easy. Unplug the quadlock from the radio (glovebox off). Add in the adapter and plug the radio back in. Job done. No wires removed, no power lines or ground needed.
Could you give us a list of everything you need, including the wiring harnesses, etc. Approximate costs of each item would also help :)
rsmagee
Drives: BlueGT (6C)
Post by rsmagee »
1 Match PP52DSP at http://m.ebay.co.uk/itm/251614870059?nav=SEARCH (he will accept on offer of £400)
1 CT10VW02 T harness http://www.dynamicsounds.co.uk/ct10vw02 ... -lead.html at £19
A few pc 20 pin extentions at a few quid each to make life easier. Image
Plus a sub if you want. Match do passaive ones you simply plug in. You also need a mic and amp to EQ it, which costs about £60 but I might see my way to lending mine to upstanding forum members. Or even better il just share my setup profiles
TheFrog
Post by TheFrog »
Many thanks. I will look into it when I have some spare cash :)
Gavin6CGTi
Drives: Polo GTi 6C
Post by Gavin6CGTi »
Hi guys,
New to this forum, I want to buy the exact same subwoofer for my 2015 Polo GTi 6C, is there anything I have to buy to make this work or can I plug it in on the original quad-lock?
What about connecting the remote wire so the sub turns on when the radios on etc.
Any insight on this would be great, cheers!
Gavin
