Hello!
My interior light is out and it will not come on. The fuse is intact. There is no power in the wires. My central locks work fine and there is power in the doorswitch at the b-column. Have you guys any idea where to start or where may the fault be at?
Kind regards, Goran
Interior Light
Re: Interior Light
Is there power on the permanent live wire into the lamp holder? Theres a door switched live, a permanent live and a ground wire
Re: Interior Light
No, nothing in the lamp holder. I know what wires you're talking about, but nothing. :S
Re: Interior Light
Thats a bit odd
Have you tried changing the fuse? Sometimes fuses look intact when they are actually blown
Re: Interior Light
Jupp! Tried that as well.. The permanent wire should not be effected if the fault is in the doorswitches or similar.. I'm out of ideas!
