6R 1.6TDI 90HP CAYB 2009
- Ugabista
- Drives: Vw Polo 6R 1.6TDI 90CV CAYB
Re: 6R 1.6TDI 90HP CAYB 2009
With a MEDIA-IN interface the front of a CD player RNS315 does not work
It should do - two independent functions
- Ugabista
Also think so but to read the description in carsystems was in doubt ...alexperkins wrote:It should do - two independent functions
http://www.carsystems.pl/vw-mdi-media-i ... id533.html
Must be something wrong there. RNS315 is just a smaller screened RNS510 which allows you to use MDI and the CD player together
What happens when you put a CD in?
- Ugabista
I explained to me wrong, I'm sorry.alexperkins wrote:Must be something wrong there. RNS315 is just a smaller screened RNS510 which allows you to use MDI and the CD player together
I have not called the MDI (5N0 035 342 E) because I lack the wiring, however to read the discretion in Carsystems I got the impression that the CD player in the RNS 315 would not work with a connected there MEDIA-IN also and before that spent money had bought the wiring, came to ask if anyone would know if it works or not ..
Oh i get you
yes CD player and MDI work together no problem
- Ugabista
Okey friend, i will make a order of wirings.alexperkins wrote:Oh i get you
Thank you very much [emoji4] [emoji106]
You are welcome
- Ugabista
Upgrade...
[emoji4]
[emoji4]
- Ugabista
Hello guys,
kindled in my car the engine light and VCDS appeared to me and error;
7397 - Diesel Particle Filter; Differential Pressure Sensor
P2454 00 [167] - Short to GND
MIL ON - Not Confirmed - Since Tested Memory Clear
Where is this sensor (part number) in CAYB engine, anyone can help me?
Someone have a diagram of the fuses box from motor?
Thank you in advance for any help.
- Ugabista
Anyone[emoji780]
Maybe like this; 076 906 051A [emoji780]
[emoji57]
[emoji57]
- Ugabista
However it reached the extension to MEDIA-IN to the right side place the lighter...
It work fine [emoji108]
- Ugabista
Solved!Ugabista wrote:Hello guys,
Substitution of the pressure sensor particle filter differential.
- Ugabista
Guys, I need an opinion / help.
It appeared to me this error in Vag-Com, which blacked out and so far has not come back ...
"Thursday,30,July,2015,19:36:23:53046
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0
Data version: 20150311
http://www.Ross-Tech.com
VIN: WVWZZZ6RZAY072238 License Plate: GFJHNKM
Address 01: Engine Labels: 03L-906-023-CAY.clb
Control Module Part Number: 03L 906 023 D HW: 03L 906 023 D
Component and/or Version: 1,6l R4 CR td H13 9970
Software Coding: 00114014000400080000
Work Shop Code: WSC 15628 784 95450
ASAM Dataset: EV_ECM16TDI02103L906023D 003009 (VW25)
ROD: EV_ECM16TDI02103L906023AH_VW25.rod
VCID: 275B8D5B5E2222190F5-8072
2 Faults Found
9867 - Coolant Pump 2
P261A 00 [096] - Open circuit
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 124787 km
Date: 2066.14.11
Time: 14:21:54
9870 - Coolant pump 2
P261B 00 [096] - Implausible signal
Freeze Frame
Fault Priority: 2
Fault Frequency: 1
Mileage: 124790 km
Date: 2066.14.11
Time: 18:54:14
Readiness: 0000 0000"
My doubt is;
Is this: 03L 121 011C
Or this: 6R0 965 561A
Will be problematic?
After 100kms not returned the error ...
Thank you in advance all possible help
2 Faults Found
Freeze Frame
Fault Priority: 2
Fault Frequency: 1
Mileage: 124787 km
Date: 2066.14.11
Time: 14:21:54
Freeze Frame
Fault Priority: 2
Fault Frequency: 1
Mileage: 124790 km
Date: 2066.14.11
Time: 18:54:14
My doubt is;
- Ugabista
Anyone[emoji845]
