Hey all
Just a quick post to let you all know that JBS are now able to take orders on their fantastic new PD TDI Nitrous Oxide System.
Using Custom REVO Technik Software with a switchable Nitrous Programme (switched via an SPS controller) the system allows full drivability and BLISTERING performance when on OR off gas.
SPS Controller:
Position 1
Stock Mode
Position 2
REVO Technik (180bhp from a PD130 for example)
Position 3
Nitrous Programme (Like Position 2, until WOT...)
How it works:
Before you set off, open the bottle.
Get into the car and, using the SPS Switch, select Position 3. Wait for the beep, then remove the SPS Switch.
Drive normally, trying not to use WOT all the time... (You shouldn't need to anyway, it's quick enough lol).
Get into a position where you would like to use the Nitrous (to overtake a truck for example).
Flick the "ARM" switch
Wait until it is safe to do so, then put your foot to the floor!!!
Once you've overtaken the truck, let off the accelerator slightly, then disarm the system by switching the "ARM" switch off.
Simple as that.
If you know you're not going to be using nitrous on the journey, simply choose the 2nd Position on the SPS switch before setting off (you can of course leave it on the 3rd Position, just try not to use WOT).
Price on application (as I'm not sure of the total cost just yet), but for your money you get:
FULL Custom Installation (and these guys know how to make a VERY neat and stealthy installation).
Custom REVO Technik Map
REVO SPS1 Switch
5lb Bottle
Highest Quality Pulsoid
Throttle Position Sensor
Digital Progressive Controller
Basically everything you need to make it work!
JBS Are on the other end of 01246 550 400
Their website is: www.jbsautodesigns.co.uk
(This has been an infomercial, by Josh_PoloGTi)
PD TDI - JBS Auto Designs NITROUS OXIDE System
- Josh_PoloGTi
- Drives: BMW E85 Z4 3.0i
- Josh_PoloGTi
Tahrey1043
- Location: Birmingham! Enjoys: The pseudo-G-Smiles provided by a 1.6 Megane Sport valver...
CHRIST...... nitrous turbo diesel
vids may be in order
EDIT ::: what with it essentially dropping a whole extra SPi 1.3-litre engine on you...
(id said 1.0 -- til i realised you added the "at the wheels" bit
carmadaaron
