http://www.ebay.de/itm/DEPO-LED-RUCKLEU ... 23279b9dcc
New full LED tail lights
Just been browsing the net and came across these, omg I want them so bad, shame they don't do a RHD set
Re: New full LED tail lights
Didn't think there was a difference between LHD and RHD rear lights, if there's not much il gladly get a pair
It's the fog lights positioning that's different, on LHD cars it's on the left not the right so would need rewiring? Could also raise an issue come MOT time
- Mart!n-GTI-DK
- Platinum Member
- Drives: '14 Polo BlueGT
Foglight and reversinglight is different.jimbo_tdi wrote:It's the fog lights positioning that's different, on LHD cars it's on the left not the right so would need rewiring? Could also raise an issue come MOT time
When there is only one of each, the foglight is allways on the side of the car that's closest to the center of the road and the reversinglight is allways on the rear corner away from the drivers side.
So the have to change sides from RHD to LHD.
- Boyracer_2011
- Drives: 1.2 Moda
Its really easy to change them mate, I got the smoked ones (not led tho) lastyear and they work great
Stop tempting me!Boyracer_2011 wrote:Its really easy to change them mate, I got the smoked ones (not led tho) lastyear and they work great
Cant we set some settings using VCDS so that we can use LHD LED tail lamps? So that fog lamps wont light up when engaging Reverse and fog lamps still works properly. Come MOT time just swap back and recode VCDS.
To throw a spanner in the works.. Im not a fan.. Think they look too cheap..
If it was me.. Id change the bulbs to CREE LED (expensive but good) and do this to tail lights which I have done.
But thats my opinion
Tooks
- Drives: 2011 Polo GTI
That mod looks good Chrispy!
I agree the rear LED lights looks bit cheap.
Which Cree's did you get?
Thanks! Very easy to do, just time consuming
Nothing yet - but quick search on ebay and you find some for £14 for pair.
Will be getting some when im comfortable laying down over £60 to do the entire set
TheFrog
- Drives: 2015 Blue GT
I agree those eBay LED lights look cheap.
I just got a set of Dectane Full LED tails lamps but they are in LHD. Without considering issues with MOT what could I do to make the white reverse light light up instead of the red fog lamps when I engage Reverse gear? VCDS? Wirings? Take the LED lamps apart? Thanks in advance for your inputs.
Hi Chrispy, please could you explain how you did this it looks great. Cheerschrispy. wrote:To throw a spanner in the works.. Im not a fan.. Think they look too cheap..
But thats my opinion![]()
just put a tape in the inside, blocking the 'eye'
attim
- Drives: 2016 6c GTI in black
Can you post a link to specific LED bulbs you used in tail lights ? Thanks
