Took delivery of new Polo on Tuesday noticed clock and date were wrong, just thought someone
in garage had set it incorrectly.
After resetting time/ date was surprised to find 2 hours later the clock had moved forward by 5 hours.
Called into VW garage and the mechanic reset clock and when we checked it had moved forward 40 mins in the space of 5 mins.
They said they had not seen this fault before and I had to book my car in next week for investigation.
Anyone here had the same problem? and if so what was the outcome.
Polo2015 1.4. Clock Problem
blackertracker
- Drives: ..
Re: Polo2015 1.4. Clock Problem
Do you have sat nav fitted? If so there is a setting to get the time from the GPS satellites.
If not, I'd first try a full reset on the head unit. It's buried in the Car - Setup menu I think.
I have just purchased a new polo and had the same problem of the clock jumping forward one hour every time you opened the door.
I have turned off the summer time mode and this seems to have cured the problem fingers crossed.
