Locked
Andrea 6r
Drives: 6r
Post by Andrea 6r »
Thank you
Polo 6c highline
Drives: Polo 6c Highline
Post by Polo 6c highline »
Hi tnx for your time to read this.I have question about Rear view camera emblem i bought original at my local vw store and i only wanted to ask is the coding and the process of installing the same?(by the way i bought the car WHIT the camera ,but it is between licence plate light and it is so frustrating when is raining outside you cant see anything...:( sorry for my bad language...:) i am from Croatia.... and here you can see my car so you now what i am talking about....tnx for your time once more!
http://www.vwclubcroatia.com/forum/inde ... ne-12-tsi/
Thank you once more ,i cant believe that somebody knows so much about car,like u....wow!! and your car is the most equipped polo i ever seen... :shock: :)
Polo 6c highline
your car is the most equipped car i had ever seen...wow!
Hello, it is a great pleasure for me to meet someone from Croatia. :wink:
I do not know how is the wiring of the original RVC Polo 6C, I guess the only thing you have to do is connect the cables from the RVC (bumper) or from the unit radio/navigator to the new RVC (emblem). For physical installation it is exactly the same.
You do not need a new coding for this, your current coding (from factory) is good for the new RVC.
Polo 6c highline
Come to Croatia on vacation! :) we are small country for big vacation!
I am glad i do not need new coding...:) i think it will be possible from rear bumper stretch cables to the trunk to the new RVC....Just one more question you think that the mechanical part (to fit RVC emblem in the trunk) will be the exactly the same as yours? In Croatia my mechanical is not interested in some new challenge and he said no it is not possible your back wiper motor is in the way and if u want camera i will need to cut the back wiper(swipe) so i can put the camera emblem??? i think that is crazy talk what do you think? whit your metal solution (http://www.servimg.com/view/18943939/141) i think there will be no problem at all!
Tnx a lot for your answer i hope that one day i can come close to have a car accessories that i want inside like you! If the trip ever brings you to Croatia Zagreb,send a msg and i will gladly show you around! :) Regards Ciclo!
Read the description of this link:
http://www.carsystems.pl/vw-rear-emblem ... d1214.html
... and make your own conclusions.
*Note that this description is for Polo 6C without any kind of rear view camera.
- Adapter:
http://www.carsystems.pl/vw-polo-6r-rvc ... d1443.html
With this adapter you can install your rear view camera for your Polo 6C exactly as in the guide that I did.
You do not need to cut (no problem with the rear wiper) any parts and installation will be perfect. :)
Thank you very much for all your comments and invitations. Image
I bought this tool to any mod that I have pending. Pleasantly surprised :shock:, it works seamlessly.
Black color ... :lol:
Spolos
Drives: Volkswagen Polo 6R Comfortline 2012
Post by Spolos »
Daar ciclo,
Can i order the cable for CH/LH for mij polo 6R? I want to order all the parts
Greetings From Holland,
Greet,
Spolos
Polo 6c highline
Tnx my friend one more time as soon i manage to fit everything i will put here some photos so you can see what i accomplished whit your big help!!!!
If i did not found this web page i would given up from my wish! thanks a million times!!!In Croatia there is a say i wish you what ever you put your hands on to turn up to gold! :D
My best regards!!!
Spolos wrote:Daar ciclo,
Greet,
Spolos
Hi Spolos,
Required:
Rain/light sensor.
Xenon headlights (from the factory) or Bluemotion. (BCMs 088, 089, 090)
In case be possible in your 6R you have two options:
- Do it yourself.
- Buy it here: https://www.x2car.de/Coming-Leaving-Hom ... egensensor
Long time ago that I no sell the automatic lights kit, but I can help you in these matters ( VCDS coding, parts you need, etc...).
Polo 6c highline wrote:Tnx my friend one more time as soon i manage to fit everything i will put here some photos so you can see what i accomplished whit your big help!!!!
My best regards!!!
Thank you, look forward to seeing those pictures ... :wink:
Andrea 6r wrote:Thank you
I need your help,
Do you have some more accurate image like this where through CCS wire towards ECU?
Andrea 6r
Drives: 6r
Post by Andrea 6r »
hello, unfortunately not .. the pictures on polovw (forum it) is like the one you've already
Edit
I found it
Andrea 6r wrote: Edit
I found it
Excellent pictures!!!
Thank you very muchImage
Andrea 6r
Drives: 6r
Post by Andrea 6r »
anything, with all the help that you provided me :D ... if you need anything else let me know ;)
Spolos
Post by Spolos »
Dear Ciclo,
Thanks for your fast respond!
I have a VW Polo from 2012 a Comfortline :(
i going to retrofit orginal xenon headlights in to my polo and this are the parts a have to build i in my car:
BCM 7H0937089F
Orginal Bi-Xenon Headlights
Plug&play Adapter cables bought from Carsystems.pl
When i am ready with this i want to build in the Rain/Light Sensor and then i want to order the CH/LH cable on x2car.de
Am i do it the right way?
do you have some tips for me?
Greetings from holland respect for what you doing on this forum
Greet,
SpoloS
Locked
