All6R.Emergency Brake Flashing (Brake light) active.(TESTED)
AVENOX
Drives: advance
Re: All6R.Emergency Brake Flashing (Brake light) active.(TESTED)
Post by AVENOX »
Hello fellow ,i am with the translator i am sorry for not to speak or write English ,but i have problems with the activation of the flashing lights of emergency and brakes ,and wiring the bcm and activated the bit .and i am not work .done all accurate as e read ,i ask help to be able to make that work many thankshello my bcm cycle is high -end is a ibiza .... have enabled several modifications .mirando elsa see you have abs module wiring to the bcm J623 cable .After .com possible switch to cable me miss the module bcm abs? .......
Hi AVENOX, welcome.
Have you checked the reference number of your BCM? Please tell me what is the reference number.
AVENOX
Drives: advance
Post by AVENOX »
hello cicle is a Ibiza and active cornering lights and preguta .my something more is whether to wire the ABS module to the bcm otherwise carries the wiring 42
AVENOX wrote:hello cicle is a Ibiza and active cornering lights and preguta .my something more is whether to wire the ABS module to the bcm otherwise carries the wiring 42
Hola AVENOX, tienes un mensaje privado, comprueba tu bandeja de entrada (inbox). :wink:
AVENOX
Drives: advance
Post by AVENOX »
bcm 6R0937086F
This function is not available for that BCM.
Bad luck, sorry for you.
AVENOX
Drives: advance
Post by AVENOX »
tell a compatible reference thanks or where I can find the reference....
AVENOX
Drives: advance
Post by AVENOX »
this is a better option ...... 7h0937088c or 7h93090A
AVENOX
Drives: advance
Post by AVENOX »
sorry that you got is what brought the car .the I carry is 6R0937087B
When we are able to solve the problem, please post the results here. :wink:
