sreeramkumars
Drives: Polo Sedan 1.2 TSI
Post by sreeramkumars »
ciclo wrote::arrow: https://www.drive2.ru/l/6491454/
VCDS autoscan?
Thanks for the pointer.
I've not fitted the stalk yet, but trying to gather required info in terms of wiring required. My VCDS autoscan results are as below -
Part No SW: 6R0 907 044 P HW: 6R0 907 044 P
Component: Climatronic H12 0614
Revision: V0000000
VCID: 40893042D3F4A91EDBD-8015
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6RU 937 087 K HW: 6RU 937 087
Component: BCM IM H+4 H35 0424
Revision: BZ035001 Serial number: 9700 019146673
Coding: 3A904ABF08A10000003800002C0B04900040414F60040000200000000000
Shop #: WSC 124697 483 00190
VCID: 6ADDB2EA8508834E259-803F
Subsystem 1 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB
Component: ------------- 006 5520
Coding: 010000
Subsystem 2 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB
Coding: 010000
Subsystem 3 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Component: E221__MFL-TAT H04 0019
Coding: 240000
Subsystem 4 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Coding: 020000
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW00WKAN7
Coding: 003036
Shop #: WSC 01234 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 499F2D66E8CE68560C3-801C
Part No SW: 6RF 920 860 Q HW: 6RF 920 860 Q
Component: KOMBI H02 0152
Coding: 140800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04719
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
VCID: 58B9F822236401DE83D-800D
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6RU 937 087
Component: GW-K-CAN TP20 H35 0424
Revision: BZ035001
Coding: 002300
VCID: F0E9208223D4F99EEBD-80A5
Component: IMMO H02 0152
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: EADD32EA0D08034EA59-80BF
Address 44: Steering Assist (J500) Labels: 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_SE12.rod
VCID: 418F3546D0FEA016D43-8014
End ---------------------------------------------------------------------
Image Image Image
:arrow: https://drive.google.com/file/d/0B2nv91 ... 90WHc/view
sreeramkumars
Thanks a lot Ciclo. I'll attempt and get back to you with how it went.
Perfect wiring for retrofitting cruise control on Polo 6R... :lol:
:arrow: http://www.uk-polos.net/viewtopic.php?f ... 55#p501833
sendoc
Drives: polo match 1.4 (6R) & Toyota Avensis T3
Post by sendoc »
My polo BCM is 6R0 937 087 H as seen on VCDS.
Will I be able to retrofit cruise control with this BCM please?
I read that some BCM ending with 087 doesn't have the pind for cruise control.
I don't want to invest in cable, switch , time and money, if it not possible with this BCM.
sendoc wrote:My polo BCM is 6R0 937 087 H as seen on VCDS.
Absolutely right, there some BCM 087 that does not support cruise control. Eg, http://www.team-bhp.com/forum/attachmen ... -087-f.png
It might be possible that you are able to retrofit cruise control on your 6R... :lol: (sorry, I'm always joking around)... at least your BCM 6R0 937 087 H supports this function.
sendoc
Post by sendoc »
Thanks for the reply and info ciclo.
sendoc, normally 1.4 petrol (non BlueGT, non GTI) have a 80-pin ECU.
The cruise control pin in the ECU 1.4 is the T80 / 24.
It is best to confirm with engine code (there several) and model year (tenth letter of VIN) of your 6R.
sendoc
Post by sendoc »
ciclo wrote:sendoc, normally 1.4 petrol (non BlueGT, non GTI) have a 80-pin ECU.
Thanks again ciclo.
The tenth letter is B. It's 2011 model .type 6R1 3E7 A05 Comfo.
Please give me the good news. :)
sendoc wrote: The tenth letter is B. It's 2011 model .type 6R1 3E7 A05 Comfo.
:wink:
sendoc
Post by sendoc »
Thanks for the info ciclo.I'll go ahead and orde the stalk and cable.
CNK
Drives: 6R
Post by CNK »
6R0 953 521 B (6R0953521B) and 6R0 953 507 B (6R0953507B) is the same part?
Will it be ok to my Polo? :?:
Is not the same, however to buy stalks (used) and install CCS in your car, either of the two is good.
521 with ring, full set from factory.
507 without ring
Ring
6R0959653 to models without ESP
6R0959654 to models with ESP, static cornering lights :mrgreen: .
CNK
Drives: 6R
Post by CNK »
ciclo wrote:Is not the same, however to buy stalks (used) and install CCS in your car, either of the two is good.
507 without ring
Ring
Thanks ciclo! I didn't know that there are so many versions of stalks :)
CNK
Drives: 6R
Post by CNK »
One more question .. Is the BCM 6R0 937 087 K is compatible with cruise control?
Could you tell me, if the wires are the same as here: https://drive.google.com/file/d/0B2nv91 ... 90WHc/view :?:
Greetings! ;)
