I have a 2007 9n3gti. Being the stylish chap I am I want to remove some arch gap.
However, I'm poor because I have two children I also don't want megaepiclows and I won't be venturing on track.
I know decent coils will be better but are springs on the polo really that bad?
Lowering ... Springs???
Teutonic_Tamer
- Drives: Polo 9N3 1.4 TDI 5dr with half a V6 :p
Re: Lowering ... Springs???
If you are genuinely happy with the ride and handling, and only seek a lower ride height, then all you need is lowering springs. However, if you intend on lowering it by a large amount, I would recommend going for stiffer dampers too, as there will be a tendency for the suspension to bottom out with standard dampers. HTH.
