mthoosen82
- Drives: 6R GTi
Hi ciclo, need your help once again, Is it possible to set needle sweep on a 6r gti? And how do I go about doing it using VCDS?
Sent from my SM-N9005 using Tapatalk
try it. 17 - instruments - adaptation - indicator celebration - set value to 1 - save
mthoosen82 wrote:Hi ciclo, need your help once again, Is it possible to set needle sweep on a 6r gti? And how do I go about doing it using VCDS?
iichel wrote:try it. 17 - instruments - adaptation - indicator celebration - set value to 1 - save
Thanks iichel
de nada
staging usually doesn't work and then it's often already given up, while on the Polo tachos, indicator_celebration has a bigger chance of succes on petrol clusters. TDI clusters don't have a lot of succesvol needle sweeps.
- CNK
- Drives: 6R
In a normal instrument cluster without MFA very often the needle test is factory disabled/locked. To turn it on you need to change the encoding in the EEPROM.
I had it in my previous cluster
mthoosen82
- Drives: 6R GTi
Hi iichel, unfortunately it doesn't work on my cluster, I tried it several times VCDS keeps on popping up with an error. Thanks guys for the help...
- CNK
- Drives: 6R
You need to find someone who can edit EEPROMmthoosen82 wrote:Hi iichel, unfortunately it doesn't work on my cluster, I tried it several times VCDS keeps on popping up with an error. Thanks guys for the help...
I attend meetings regularly and on TDI tacho's it hardly ever works. Petrol clusters is about 50/50 (maybe even more). GTI clusters hardly ever while GT clusters often do work. No experience with the WRCCNK wrote:In a normal instrument cluster without MFA very often the needle test is factory disabled/locked. To turn it on you need to change the encoding in the EEPROM.
iichel, I have to teach a trick. Tomorrow, by email.iichel wrote: I attend meetings regularly
Then if you want, you share in your meetings.
you teach me or I teach you?
- Mart!n-GTI-DK
- Platinum Member
- Drives: '14 Polo BlueGT
iichel wrote:you teach me or I teach you?
Pretty self explanatory.ciclo wrote:iichel, I have to teach a trick.
Hey @ciclo
I have a 2010 6R GTi (no xenons) with auto wipers. You seem like the guy to ask; can I retrofit auto headlights?
Sorry if this is the wrong place to ask. I'm new and the forum will not let me message yet
Thanks!
Thanks!
teach you ... dammit!
Waldi
- Drives: Polo 6R 1.6 TDI
Hey ciclo, it is amazing what you do with the 6R!! I love it! I have a a question. I am Germany and would like to install the Mfsw of the Golf 7 GTD in my Polo 6R 1.6 TDi from 2010 (Highline). I bought the MFsw with all buttons. My oem steering Wheel has no buttons. I have the mfa+ from the 6R GTI and cruise control.
Can you help me which parts i need to complete my project?
Greetings
Waldi
Greetings
Waldi
