Bi-xenon led headlight lense removal
Willni
- Drives: Polo '14 6R, Golf 07' Edition 30
anyone tried to or know hwo to remove the lense of the headlight, so I can clean some residue off?
- Mart!n-GTI-DK
- Platinum Member
- Drives: '14 Polo BlueGT
Re: Bi-xenon led headlight lense removal
Like this.
Willni
Thank you!
- Mart!n-GTI-DK
- Platinum Member
Instead of his box you can use an ordinary oven in the kitchen at around 80 c degrees.
wrecksigge
- Drives: 2012 Polo GTI
I did this on a pair of devileyes wich i bought second hand for my old Golf. I got them cheap because of some dirt and scratches on the inside of the lense in one of the headlights. I just have to warn you. It is a PAIN and it will really put your patience to the test. I did not put it in the oven tho, i sat with a hot air gun while prying with various tools. You really need to keep the glue warm all the time, because the second it cools its really strong. And when its warm its really sticky! Be sure to seal it properly when you mount it back to avoid any moisture building up in the headlight in the future.
