HI all
I have a few problems with the mrs 2001 1.0 (AUC) 6n2
Recently taken it for mot and failed on emissions high HCO and CO2
So we done some tests and found out the Head gasket was gone so I have changed that and emissions are now a lot better no white smoke
I now have started up for the first time and I heard a small pop and found the oil pump seal have let go and leaking oil I am have problems undoing the crank bolt can anyone help with telling me how I can lock the crank off and if the thread is left handed or right handed
So Far I have tried
locking off camshaft but the cambelt slips when tension is applied
removed the started motor and used a big screw driver on the flywheel
But to no avail
I do have a replacement oil pump to fit and a crankshaft seal
Hi All Got a Few issues
Re: Hi All Got a Few issues
You need a flywheel locking tool
It's a standard bolt ie undoes anti clockwise
if it is not to much trouble could you link me to one please I cant seem to find one
Could you please link me to one I cant find any on gsf euros or ebay it would be very help full
Presume this is the crank seal on the Cambelt side?
Sorry yes this is cam belt side
just a question how does this work looks flat and the flywheel is round and I cant find the car in sealey website under this tool
It locks into the teeth via the starter hole
Have you got a Haynes manual? The process is detailed quite well in there
