[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Auto headlights (after market) - UK-POLOS.NET - THE VW Polo Forum
I want to pick one up as I can't be fussed with oem hacking and slicing bcm wiring and installation seems to look easy on this one, not to mention is adds ch/lh lights!
I have heard horror stories that the switch doesn't illuminate in the dark? Opinions please!
I've read quite a few threads on these. Can anyone clarify what additional wiring etc needs to be done. I'm guessing it's not as simple as plug and play. Some threads mention wiring into the BCM module, others installing relays. Then recoding through vcds
Are there different versions of these some easier to install than others.
Yes please tell us which one you ordered, they look fairly simple. module sits between light switch and cable connector, light sensors sit behind a pillar trim.
Only thing is you don't want to cheap out on it because some people report their auto light switch not lighting up at night (no red illumination on dial)
