88F has an internal gateway in the bcm I think
PQ25 BCM 088B & 088F at first they were used for BlueMotion models as you know, they do not have the pins T73b/22, T73b/23 (CAN bus diagnosis low, high), so an external Gateway for diagnosis is necessary if these BCM models are installed.
you're right, I mixed something up
- federicodrdpro
- Drives: White Polo 6R TDI
Yes I will write the results!ciclo wrote:.....federicodrdpro wrote:Thanks Ciclo for the answer! I have a Polo 6R 1.2 TDI not Bluemotion. My BCM is a 6R0 937 087 K version with firmware 0251.
I bought 1K8419091AF steering wheel and 5G0880201J airbag. I don't understand if the 5k0959542 control unit in necessary for the MFSW with 1K8419091AF steering wheel.
I don't see control unit in ETKA 7.5. Can you tell me the wiring links?
For the buttons illumination, I think this is an economic solution: http://www.mk5golfgti.co.uk/forum/index ... #msg999999
P.S. I don't have MFSW in my Polo now.
Federico
Tell us the results. Operation buttons and lighting.
- A question about the "Rear 12v SOCKET oem"
In ETKA 7.5 the part number of "Rear 12v SOCKET oem" is: 1J0 919 341 . But there are two versions. 1J0 919 341 J and 1J0 919 341 H.
One is for front use and one is for baggage car use. The difference is the openining direction of "door SOCKET".
I want your version:
http://www.servimg.com/image_preview.ph ... u=18061781
Not this:
https://a-a.d-cd.net/560ec5cs-960.jpg
Which is the part number of your Rear 12v SOCKET oem?
EDIT:
Ciclo, What do you think about panic function into key FOB? Panic function is a retrofit in a older Polo.
There are two type of Key, 315MHz and 434MHz. In UE the frequency used is the 434MHz.
The part number of the 434MHz version is: 5K0837202A
-http://www.myturbodiesel.com/threads/ne ... -fob.5742/
- How to new key open: https://www.youtube.com/watch?v=V1snxXcUEXA
Federico
Last edited by federicodrdpro on Wed Mar 23, 2016 3:22 pm, edited 4 times in total.
- CNK
- Drives: 6R
Do you know what is part number of rear 12V socket from Golf 7 Variant baggage:
I would like to retrofit a 12v socket in my trunk
?I would like to retrofit a 12v socket in my trunk
- Mart!n-GTI-DK
- Platinum Member
- Drives: '14 Polo BlueGT
I would love to have both sockets in mine.CNK wrote:I would like to retrofit a 12v socket in my trunk
- CNK
- Drives: 6R
I bought inverter but can't find this 12v socketMart!n-GTI-DK wrote:I would love to have both sockets in mine.CNK wrote:I would like to retrofit a 12v socket in my trunk
what about the 3C0919565C for the 230V socket?
In rear side (cup holder) I used the original 12V socket from front side.federicodrdpro wrote: Which is the part number of your Rear 12v SOCKET oem?
Just a tip: 12V 'dummy' instead of cigarette lighter --> 7L6919311
- CNK
- Drives: 6R
Many thanks ciclo! I guess I'll have to install ETKA because http://ifinterface.com/prog/car/prog2/inprog.php is too slow and crashed very often..
federicodrdpro wrote: Ciclo, What do you think about panic function into key FOB? Panic function is a retrofit in a older Polo.
The part number of the 434MHz version is: 5K0837202A![]()
Federico
It is an interesting feature, but I don't like it. I prefer that anybody to get nervous in complicated situations...
... with terrible consequences.
- Mart!n-GTI-DK
- Platinum Member
There is a lid on the 12V socket iichel. So I don't think that will be a problem.iichel wrote:Just a tip: 12V 'dummy' instead of cigarette lighter --> 7L6919311
Yes that's true but my car came with a cigarette lighter and I don't like it. And I don't really want to take out the entire centre console to change the cigarette lighter. :p
