Rcd 310
Asamoli
Drives: 1.2 TSI (105) SEL polo 6r
Rcd 310
Post by Asamoli »
Anyone fitted DAB to an rcd 310? Is it possible and how hard would it be to do, also is it worth installing a Bluetooth module? Heard the audio isn't too good? And how hard is it to do?
vc-10
Re: Rcd 310
Post by vc-10 »
It's a new radio I'm afraid. Unless you add something like those Pure systems, which have a little dongle. You'd need a new antenna too, either one stuck on the window somewhere or by replacing the factory one.
If you want Bluetooth and DAB, and a factory look, best bet is to find a DAB version of the RNS 315 with built-in Bluetooth, like this one off eBay. You'd have nav too then.
http://www.ebay.co.uk/itm/VW-RNS-315-DA ... Swy5ZXCPIq
The non-DAB ones are a bit cheaper.
Asamoli
Re: Rcd 310
Post by Asamoli »
Cheers mate
