Air filter box questions
lfcadam1993
Drives: Vw polo 6n2 1.0
Post by lfcadam1993 »
Ok hello everyone! This may well be the stupidest question ever but I am very much a rookie when it comes to cars. I have a question that I'm guessing one of you more educated folk can answer. How many air filters are inside my air filter box unit on my 6n2 1.0??
2015_polo
Drives: 2015 6c polo
Re: Air filter box questions
Post by 2015_polo »
Hi there is 1 air filter in the air filter box
Sent from my SM-G920F using Tapatalk
lfcadam1993
Are there any other filters inside?
alexperkins
Site Admin
Post by alexperkins »
There's a fuel filter and an oil filter
2015_polo
Re: RE: Re: Air filter box questions
Post by 2015_polo »
lfcadam1993 wrote:Are there any other filters inside?
just the 1 inside the airbox but as mentioned you also have a oil filter then at the back of the car you have a fuel filter and im sure on the 6n2 the pollen filter is under the scuttle panel
lfcadam1993
Thanks for the comments everyone, but should there be an air filter in the box thing that goes over the throttle body? Let me try and explain how mine looks, as the cover on the engine sits as you look at it as standing at the bonnet theres some kinda filter to the left, then the part that goes over the throttle body then theres a filter to the right, but my question is should there be an air filter in the middle compartment thats is sitting over the throttle body? Thanks
2015_polo
Post by 2015_polo »
Yes in the box that will say 1.0 mpi on it there will be an air filter
Only filter i can think of that could be on the left is the charcol filter or if someone has fitted an aftermarket filter to the end of the air intake leading to the filter
