Audi A1 seats in 6r
Willni
Drives: Polo '14 6R, Golf 07' Edition 30
Audi A1 seats in 6r
Post by Willni »
Ok So i'm planning to put in Audi a1 s-line seats in my car and have a couple of questions.
I found a cheap half leather set
1. I currently have heated seats can i transfer this over?
2. Is it easy to swap over the heating pads to them?
3. they are from a 5-door will this affect either the front or back seats?
4. Doorcards can be thrown in i take it these won't fit?
daydotz
Re: Audi A1 seats in 6r
Post by daydotz »
Seats will fit heating won't be easy to swap if uts even possible jf you have a 3dr car then sests from a 5dr wont tilt to enable passengers into the back seats
Willni
Post by Willni »
daydotz wrote:Seats will fit heating won't be easy to swap if uts even possible jf you have a 3dr car then sests from a 5dr wont tilt to enable passengers into the back seats
thanks for the reply :) I'm sure ciclo or mart!n will see this at some point and enlighten me on the heating element haha :D
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
The heating elements are possible to move from one seat to another. BUT!!! it means that you have to completly skin both sets of seats to fit them.
Since you bring up the fact that they are from a 5 door model I assume that yours is a 3 door Polo? It doesn't affect how they sit in the car. Both front and rear seat fit.
The padding on the rear seats are a bit larger than in the Polo so the will wrinkle a bit on both end.
But the doorcard will nok fit on either a 3- or 5 door Polo.
Normally there is a plug under the seats that are different from the A1 to the Polo. But I think it it the seat heating plug so that shouldn't be a problem either.
So in colclusion. It is possible... But it involves a bit of work.
Willni
Post by Willni »
Lol knew you'd see it Mart!n :P thanks for the info
colgy
Drives: Polo 6R 1.6 TDi
Post by colgy »
Hi guys, wonder if you could help with the same thing?
I'm trying to fit Audi A1 seats into my polo - thought it'd be straightforward since they're both the basic non-heated seats, but the Polo has 3 connectors:
ImageUntitled by Colgy, on Flickr
Whereas the Audi seats only have 2 connectors:
Does anybody have wiring diagrams so that I can see which wires I have to use?
golffather
Post by golffather »
Did you get any more info on this
arron99
Drives: 2014 tsi
Post by arron99 »
Did anyone solve the airbag wiring on this? I want to do the same thing.
Surely there should be one connector for the airbag and one for the seat belt pre tensioner. What's the third one for?
rashel54321
Drives: 6R
Post by rashel54321 »
Was there anyone able to complete this without warning lights? How did you deal with the wiring?
Lewis_polo12
Drives: 6r match 2012
Post by Lewis_polo12 »
rashel54321 wrote: Thu Apr 27, 2023 1:21 am Was there anyone able to complete this without warning lights? How did you deal with the wiring?
did you manage to do this?
