RNS 510 question
Nlolotte
Drives: Polo 1.2 R-Line TSI 6R
RNS 510 question
Post by Nlolotte »
If i buy RNS 510 will navigation automatically show on my highline mfd or do i need to code it in?
CNK
Drives: 6R
Re: RNS 510 question
Post by CNK »
You need other instrument cluster (BlueGT or WRC or GTI)
Nlolotte
Post by Nlolotte »
i have the glut gt one already
Then you'll be fine
Nlolotte
Post by Nlolotte »
thank you! so plug and play no vcds?
habib_123
Drives: Polo 6R 2012 1.2TDI RHD
Post by habib_123 »
If you do install the RNS-510 you will need to code it into the car (VCDS). Go into CAN Gateway installation list and tick the box for navigation.
Once done go back out, and into navigation and check coding. I can provide mine if needed.
Good luck!
