PICTURES TO FOLLOW
One the best OEM modification's for your 6C or 6R, there various threads in this forum on how retrofit the Bi-Xenon Headlights (Very similar installation process for LED headlights)
Outstanding quality compare to most aftermarket headlights units on the market, these are the GTI version with the red stripe inside the headlight.
Headlight come brand new retrofit xenon adapters.
Headlights are in used and in good full working condition.
Will require coding to your car, various options to fit depending on how you want to setup the lights, factory setup with sensors etc or simple retrofit.
Most vehicle's may require a additional upgrade to a Highline BCM or 6C Highline BCM for a 6R, to enable for the headlights to be working correctly.
Also additional wiring & configuration necessary.
Can assist with coding & fitting at extra cost.
RRP £1600.00 new from VW complete ballast
Looking for £900.00 ONVO Plus Postage
Collection welcome or Posted within the United Kingdom & Europe
Verified Paypal & Cash On Collection.
Based in Essex/London
PM for more info
