Pin Out BCM 7h0 937 090 B
Joe51
Drives: 6R
Post by Joe51 »
Hello!
Does anyone know the Pin out for the following BCM? IT's out of a beetle 5c (I think it's the same like Polo 6R etc) made 2014. Thx. Need that to install PDC :-)
PNr.: 7H0 937 090 B
Re: Pin Out BCM 7h0 937 090 B
Hi, Welcome.
No need to connect anything directly to the BCM, it's hardest.
What you need:
Supply
- A wire 0.5 mm from T16/1 (16-pin connector, slot 1) of new parking control unit to Fuse SC13b 5Amp +15 (wire green/black).
- T16/8 ground (brown)
CAN line new parking control unit
- Low---- from T16/15 (orange/brown) to CAN Low in any other control unit of powertrain.
- High---- from T16/6 (orange/black) to CAN High in any other control unit of powertrain.
Some control units powertrain: Instrument cluster, Additional instruments, Headlight range control unit, Steering column electronics control unit, Power steering control unit, BCM, Engine, ABS... Choose the one you prefer to make an easy installation.
Parking aid button
The rest are the sensors and buzzers connected to the control unit J446. T12 connector/s
Joe51
Drives: 6R
Post by Joe51 »
Hello!
Thx a lot! I will try my Best on weekend! Its a pdc without button and only for the rear bumper! I will tell you how it works! Thx
Joe51
Drives: 6R
Post by Joe51 »
Hello again! PDC Check ! There is no gateway - did it with the bcm connectors 18 and 19 !
I will upload a manual in few days!
Ok!, the important thing is it work properly.
PDC it's a nice improvement. :wink:
