govindsharma
- Drives: polo 1.2 petrol HighLine
Good Evening Ciclo Sir Please help me regarding this issue in my car.Sir when i unlock car with remote all the doors get unlocked but when i unlock the car with key input in driver door only driver door opens other three remains unlock and i have to push unlock button in driver door.Sir i had not activated selective door function in my car with VCDS.Please tell me why this happens.
Thanks in advance to you.
@ciclo
You were right..
When you mentioned that the problem could be in the coding, i gave it a try..
I had my old coding, which i copy paste..
Well the error is gone and everything works smooth again!
Verstuurd vanaf mijn Lenovo K50-t5 met Tapatalk
You were right..
Current BCM codinggovindsharma wrote:Good Evening Ciclo Sir Please help me regarding this issue in my car.Sir when i unlock car with remote all the doors get unlocked but when i unlock the car with key input in driver door only driver door opens other three remains unlock and i have to push unlock button in driver door.Sir i had not activated selective door function in my car with VCDS.Please tell me why this happens.
Try with this BCM coding:
7AB02BFF48A10000013806006CAB069000C0414F608C2000200000000000
Byte0 Bit6 marked
... tell us the results.
Ah!... Lord, please do not tell me Sir.
Please you must open your own topic, and show us your beautiful car. Share it with us.
It is out of respect for all forum users. Each time there is a reply in my topic rises to the top of reading (MKVIII (6R/6C) Polo (inc GTI) - Years 2009-Present) and this is not fair for other users. TIA
I thought so, but it was not sure 100%Rud031 wrote:@ciclo
You were right..
I'm glad for you.
maybe in combination with byte 17 bit 3?
so to summarize image 1 from 2.0 TSI engine CJK (7L6):
ECU T94/64 is the cruise control pin that we also use
ECU T94/46 is not the pin that we use but image dows
The wire goes to T41/11 stalks. Normally T41/10 is MFSW linbus.
The wire goes to T12/9
The wire goes to T5/3 MFSW
what is the function of this wire anyway? DSG? Cruise control?
94/44 is specific to the CCS button connection in wiring loom to T41/26 and T41/29.
6R: T94/45 (TSI) or /64(TDI) to T41/26 and /29 Similar to ccs on stalks. Wire goes to T73b/45 too
Star 5: only for vehicles with multifunction steering wheel
to summarize image 2:
T73b/36 on the bcm is currently the alarm horn (LIN backup horn)
goes to T41/10 (in 6R this is linbus)
goes to T12/9 in airbag wiring harness (in image 1 T41/11 goes to T12/9!)
There is another wire from t5/5 GRA (cruise control)
To T41/11
To T12/8
To ECU T94/46 (TSI) or T94/44 (TDI)
In summary, different steering angle sensor/slip ring, due to differences in where T12/9 from the air bag wiring harness goes (T41/11 or T41/10)
So ECU T94/46 is a linbus connection?
To T41/11
To T12/8
the longer you compare the images, the more confusing they get. i'm on my 5th edit now
in my PDF, maybe an older version that I found somewhere in my mailbox, there is no notice of this pin at all
version 2016.03 (1st page bottom right corner)
The first image (with red arrow) is a correction (new update from Erwin), but this correction is not possible.
The LIN for buttons can only be connected to the BCM (Gateway) not to the ECU. So the second image is correct.
These two images belong to the same document. VW T6 (downloaded this morning)
I guess it will be very confusing for workshops or vw dealers. I guess, because ... hmm... I prefer not say anything.
Additionally, all this mess leads me to think that our bcm firmware/software is outdated. Hahahehehahahehehaha!
Some time ago (in the Middle Ages ... haha hehe!) I tried to install this multifunction steering wheel ...
viewtopic.php?f=56&t=58703&start=2010#p506733
Subsystem 7 - Part No SW: 6C0 959 442 C HW: 6C0 959 442 C
Component: E221__MFL-DC1 H03 0102
Coding: B0FFFF
Note: If the Byte17 Bit2 is enabled these buttons disappear, but Byte17 Bit2 is correct for these buttons.
I got two faults in engine control unit related with ABS unit... according ODIS program (VW dealer), but no way to operate the cruise control buttons although all functions from these ccs buttons are recognized in my ECU. The rest of buttons (right side) worked perfectly...
My last autoscan:
Coding: B0FFFF
Friday,04,March,2016,13:29:23:06516
VCDS Version: 15.7.3.0
Data version: 20151216
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0ciclo License Plate: CCS BUTTONS MFSW
Mileage: 17410km-10818mi Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 03 08 09 10 15 17 19 20 25 2E 37 44 55 56 77
VIN: WVWZZZ6RZDY0 Mileage: 17410km-10818miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GD HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 2686
Revision: --H10--- Serial number: 00000000000000
Coding: 001100D6202400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070GD 004004
ROD: EV_ECM12TFS02103F906070FJ.rod
VCID: 6A6F2A343F080FD83D-803E
2 Faults Found:
6117 - Function Restriction due to Implausible Message(s)
U1112 00 [039] - -
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 17415 km
Date: 2016.03.04
Time: 01:45:59
6116 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Fault Priority: 6
Fault Frequency: 1
Mileage: 17415 km
Date: 2016.03.04
Time: 01:45:59
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3216D00B5842814EA84D300401700
VCID: 0207FA0C93107F307D-8056
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 383196AE4F0E3BBACD-806C
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0733
Revision: B9080001 Serial number: 0771 100150209
Coding: 3CB02FBF08E1240093380E916CEB8FD0DAC0672F600D30D0200000030840
Shop #: WSC 03607 002 104857
VCID: 6861363E0F1E1BEA4D-803C
Subsystem 1 - Part No: 5K7 955 559 B
Component: RLS 110215 03 37 0059
Coding: 0228DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Coding: 1000AB
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Coding: B0FFFF
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Coding: 18BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Coding: 18BC32
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361212601014
Coding: 308001
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E3B82B06F2C078C9D-806A
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01JKVVP
Coding: 00314D
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 4A4F6AD4BF68CF383D-801E
Crash sensor for side airbag; driver side:
Serial number: 3575HRB405N1C4LI7929
Crash sensor for side airbag; front passenger side:
Serial number: 3585HRB405B1D5MS8GS2
Crash sensor for side airbag; rear; driver side:
Serial number: 3515RRB405B17ABS901.
Crash sensor for side airbag; rear; passenger side:
Serial number: 3525RRB405B181TUDPKC
Part No SW: 6R0 920 870 C HW: 6R0 920 870 C
Component: KOMBI H05 0607
Coding: 140E01
Shop #: WSC 00233 572 91226
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 353290974B11494FD5-8060
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0733
Revision: B9080001
Coding: 002200
Address 20: High Beam Assist. (J844) Labels: 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404001C00000000000000
VCID: 2E2BA2802FFC677C1D-807A
Component: IMMO H05 0607
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662584630
Coding: 010100
VCID: 2A2FAA7437C88F183D-807E
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H06 5218
Revision: AB001001 Serial number: VWZ6Z7L7654213
Coding: 04000442040000A10001
Shop #: WSC 12345 123 12345
VCID: 373094AD4B0B3DBDC5-8062
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V13 8348
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F28A485BFF36D7505-807A
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
VCID: 7770146D434BBD7DC5-8022
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664158506
Coding: 0501000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3B3C8CB9733F15A1A5-806E
End-------------------------(Elapsed Time: 03:19)--------------------------
My last autoscan:
Friday,19,August,2016,09:48:27:06516
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate:
Mileage: Repair Order:
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 77 0B
VIN: WVWZZZ6RZDY0CICLO Mileage:
VCID: 6A0F8AD4DFA86FC44C-803E
Revision: --------
Shop #: WSC 40308 002 104857
VCID: 02A75AAC33B0DFEC0C-8056
Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb
Component: LENKW.SENSOR H06 0060
Serial number: 090465LEA0003X
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7E1B62100F0CE7502C-802A
Revision: V0000000
VCID: 38D1F64EEFAE9B66FC-806C
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Coding: 3CB02FBF48E1240093380E917CEB9FD0DAC8672F600D30D0200000030800
VCID: 680196DEAFBE7B367C-803C
Coding: 0728DD
Coding: 0200A3
Coding: 1000AB
Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H03 0103
Serial number: 27140003142720054516
Coding: A4FFFF
Serial number: KU0KU003051200017821
Coding: 18BC32
Serial number: KU0KU010051200012315
Coding: 18BC32
Coding: 308001
VCID: 3EDBE2500FCC67102C-806A
Coding: 00314D
VCID: 4AEFCA745F082FE44C-801E
Coding: 140E01
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 35D2F037EBB1A953E4-8060
Revision: B9080001
Coding: 002200
Revision: AA001001
VCID: 2ECB0220CF9CC7A0AC-807A
Coding: 010100
VCID: 2ACF0A14D768EF844C-807E
VCID: 37D0F44DEBAB9D61F4-8062
Coding: 11250
Shop #: WSC 00788
VCID: 2FC804255F93CDA9B4-807A
VCID: 7710740DE3EB1DA1F4-8022
ROD: EV_UHVNA.rod
VCID: 3BDCEC5913DF757DD4-806E
End-------------------------(Elapsed Time: 04:16)--------------------------
benzinkopf
- Drives: 1.2TSI 105HP DSG7
Ciclo Sir!
How bout this? Possible in 6R?
Transporter T6 has it so technically we could try. But the polo does not have the OEM parts for it
benzinkopf
Im planning to explore the internal components. We may be able to retrofit to polo parts.iichel wrote:Transporter T6 has it so technically we could try. But the polo does not have the OEM parts for it
The issue that you'll find is probably the mirror glass and a way to fit the sensors to the rear bumper
With BCM 7E0 it is electrically possible if you use two Side Assist units and isolation relay for CAN line (powertrain) from VW T6, a different thing is how attach this units on the rear corners inside the bumper ...
The activation switch is a simple switch, so yes.
The warning lights (amber) can be fixed in a visible place inside the door, so yes.
VCDS coding? I don´t know. Search in VW Transporter forums.
- CNK
- Drives: 6R
It's available also in VW Jetta, here is some movies: https://www.drive2.ru/l/9224455/
Ciclo, Are you able to give the number and type of pins, which need to modify the folding mirrors with module k418? In your post on this modification, several images is quite small. It's hard to see how this is the pin. Can you help?
I decided on k418, because it is hard to find the right window motors.
