Drivers side window switch removal
gripperjonesboy
- Drives: Match
Hi new to this forum, need some help - left the drivers side window slightly open on my 3 door 2011 Polo over the weekend and the heavens open !!!. Now the electric window switch won't operate - do I need to remove the door card to access the switch, or can I prise it out?
- Robby71
- Drives: 2019 Golf R-Line EVO
Re: Drivers side window switch removal
You might damage the surround by prising it out so better to remove the door card and access it from behind.
Have you checked the fuse to see it that's blown?
gripperjonesboy
- Drives: Match
Can anyone tell me which is the fuse for the electric window switches on a rhd 3 door 2011 polo match. Also a part number for a replacement switch as system. Thanks
