Do not worry orIoN, often happens ...ORiOn wrote:Yup! That was it! haha #fail
Today I made the instrument panel factory setting and unfortunately it has not happened anything important. The only good thing was that I learned a bit of German language.
Also a new Autoscan: (after trying some tweaks w/o success)
Wednesday,14,September,2016,14:25:37:06516
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: TACHO FACTORY SETTING
Mileage: Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 77 0B
VIN: WVWZZZ6RZDY0CICLO Mileage:
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GD HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 2686
Revision: --H10--- Serial number: 00000000000000
Coding: 001100D6202400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070GD 004004
ROD: EV_ECM12TFS02103F906070FJ.rod
VCID: 6AA7F27C4750C75C24-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3216D00B5842814EA84D300401700
Shop #: WSC 40308 002 104857
VCID: 023FC234AB583704E4-8056
Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb
Component: LENKW.SENSOR H06 0060
Serial number: 090465LEA0003X
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EB3CAB8B7B45FE884-802A
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 38695ED68756F3FE54-806C
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0733
Revision: B9080001 Serial number: 0771 100150209
Coding: 3CB02FBF48E1240093380E917CEB9FD0DAC0672F600D30D0200000030800
Shop #: WSC 03607 002 104857
VCID: 6899FE664726D34ED4-803C
Subsystem 1 - Part No: 5K7 955 559 B
Component: RLS 110215 03 37 0059
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Coding: 1000AB
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H03 0103
Serial number: 27140003142720054516
Coding: A4FFFF
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU003051200017821
Coding: 18BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU010051200012315
Coding: 18BC32
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361212601014
Coding: 308001
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E734AF8B774DFA884-806A
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01JKVVP
Coding: 00314D
Shop #: WSC 01383 785 00200
VCID: 4A87321CC7B0877C24-801E
Serial number: 3575HRB405N1C4LI7929
Serial number: 3585HRB405B1D5MS8GS2
Serial number: 3515RRB405B17ABS901.
Serial number: 3525RRB405B181TUDPKC
Part No SW: 6R0 920 870 C HW: 6R0 920 870 C
Component: KOMBI H05 0607
Coding: 140E01
Shop #: WSC 00233 572 91226
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 356A58DF935901EB7C-8060
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0733
Revision: B9080001
Coding: 002200
Address 20: High Beam Assist. (J844) Labels: 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404001C00000000000000
VCID: 2E636AC877043F3804-807A
Component: IMMO H05 0607
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662584630
Coding: 010100
VCID: 2A6772BC4F10471C24-807E
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H06 5218
Revision: AB001001 Serial number: VWZ6Z7L7654213
Coding: 04000442040000A10001
Shop #: WSC 12345 123 12345
VCID: 37685CD58353F5F94C-8062
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V13 8348
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F606CCDF73B25C10C-807A
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
VCID: 77A8DC958B9375394C-8022
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664158506
Coding: 0501000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3B7454E1BB47ED95AC-806E
End-------------------------(Elapsed Time: 04:03)--------------------------
This month I will go back again to the VW dealer to try to update some units of my VW --- BCM, Gateway, ECU and Intruments --- to try to get some changes in MFA functions (GRA_High, etc...).
Du, kluge Spanische Mann, sprichst und verstehst ja gar gut Deutsch!
Michel, please can you explain me the difference between 'verbaut' and 'sollverbau'?
Verbaut = installed (the verb 'verbauen' is 'to install')
'soll' comes from the verb 'sollen' which compares to the verb 'to shall'. 'ich soll verbauen' is translated into 'i should install'
So the word sollverbau is a contraction of soll and verbauen.
It means a component should be installed
Michel, you are the best
Curiosity: BCM PQ25 Byte18 Bit6 (7E0937090)
Conditions: Polo 6R with 6C LED headlights and 6C taillights.
The warning light of instruments come on only when the brake pedal is actuated... with the following coding.
Solved with:
So Byte18 Bit6 is affecting the brake lights performance.
Solved with:
Byte 18 is closely related to lighting. What I think
Xenon + LED DRL = Hex 67 (polo 6R)
LED + LED DRL = Hex 73 (T6), I have used this value too
Halogen H7 = Hex 41 or 65
Halogen H4 = Hex 61 (polo trendline and bluemotionn)
Crossfox = Hex 62 or 42iichel wrote:Byte 18 is closely related to lighting.
...- ciclo
New Ibiza
Great!
Ah yes, I forgot: (Sorry, but lately I have the fish memory (3-5 sec)
, I can not even remember the speed at which I SET the cruise control and then be able to RESume)
similar to this
Great!
On October 6thciclo wrote:This month I will go back again to the VW dealer to try to update some units of my VW --- BCM, Gateway, ECU and Intruments --- to try to get some changes in MFA functions (GRA_High, etc...).
similar to this
peter_dk25
- Drives: Blue GT
govindsharma
- Drives: polo 1.2 petrol HighLine
Dear ciclo you had said that i have to change my car BCM for xenon headlight and auto fold side mirror,dear please suggest me which BCM i will buy and can i replace mine with myself and code with VCDS, can my car accept new BCM without any error.
Thank you
Thank you
On the German forum for VW POLO i read that in the window motor is the most important code PR-6XE if you want to run the function folding.
Ciclo do this modification on 6R0959801BD Z0D, 6R0959802BF Z03.
On etka.cc found many motors code PR-6XE. Is anyone doing this modification to the motors 6R0959801BC Z03 and 6R0959802BH Z0D? Will this work?
Coding VCDS will be the same?
peresurin
- Drives: 2015 - 6C (Lounge)
hello ciclo,
first of all i am very impressed of your skills and technical knowledge. I read all this subject from start to end. I have some questions. you stated that you used below LEDs;
viewtopic.php?f=56&t=58703&start=285#p479470
But i can not find them anymore (actually i found one but I just want to be sure), is it possible to use below products for this fog-lamp mod;
1) https://www.aliexpress.com/item/A-Pair- ... c6236caef3
2) https://www.aliexpress.com/item/Night-L ... c6236caef3
or this one>
3) https://www.aliexpress.com/item/1set-60 ... f826051b1b
The third one is your product i think? I kindly ask you to advise which one fits well w/o error.
Thank you in advance for your reply.
or this one>
To change your BCM High by Max you need rewiring of most of its lights. This rewiring is required if you want OEM Bi-xenon headlamps, OEM LED headlights, OEM Automatic lights, etc ... but not for OEM automatic folding mirrors.govindsharma wrote:Dear ciclo you had said that i have to change my car BCM for xenon headlight and auto fold side mirror,dear please suggest me which BCM i will buy and can i replace mine with myself and code with VCDS, can my car accept new BCM without any error.
Thank you
Therefore there is no such BCM which you refer in your previous question --->Plug & Play
Favi only by testing will be possible give an answer to your question.favi wrote:On the German forum for VW POLO i read that in the window motor is the most important code PR-6XE if you want to run the function folding.
You should never forget to do this after coding
Coding should work: Folding mirror with remote--> (J386) Byte2 Bit1 enable.
Example LHD
Example RHD --- if J386 1000A1 ---> 1000A3
I even thinking about buy a new 6C 1.0 (LED headlights) to replace the 9N3 ...peter_dk25 wrote:![]()
A-Polo ---> a very attractive version sold in Spain, to achieve the moon and perhaps Mars.
(by gravitational effect, I guess
