why buy a 6C? you already have one
Thank you very much for Ciclo answer;) I ordered these motors have mentioned and we will be tested. If you do not work, then I stick to the installation of the K418.
govindsharma
- Drives: polo 1.2 petrol HighLine
Dear Ciclo I have power folding side mirror please tell me either i have to change window motors and BCM to get auto lock unlock auto side mirror or by changing wires as described /viewtopic.php?f=56&t=58703&p=481352#p481352 i will get this.Dear how can i check that my car power windows motor is compatible for auto fold.My car is RHD
As described
Driver's door: Three wires.
-T10f/4-------to------- T16g/15 (J386)
-T10f/2-------to------- T16g/14 (J386)
-T10k/8-------to------- T16g/12 (J386)
Passenger door: Two wires.
-T10v/4-------to------- T16l/15 (J387)
-T10v/2-------to------- T16l/14 (J387)
Thanks in advance.
As described
Thanks in advance.
My R-line is still a great 6R, as I said once, it is the best VW model to learn when oneself is hobbyist to modifications. E.g some Polo 6R still have simple switches instead of Hall sensors. (Klaus von Klitzing)iichel wrote:why buy a 6C? you already have one![]()
6C is the next level of learning, there are several modifications that oneself can do without a great effort. E.g the folding mirrors...
iichel, in our case the 9N3 1.2 60hp would be replaced by the 6C 1.0 75hp.
Ok, if you have problems with coding contact me.favi wrote:Thank you very much for Ciclo answer;) I ordered these motors have mentioned and we will be tested. If you do not work, then I stick to the installation of the K418.
viewtopic.php?f=56&t=58703&start=2370#p512295govindsharma wrote:Dear Ciclo I have power folding side mirror please tell me either i have to change window motors and BCM to get auto lock unlock auto side mirror or by changing wires as described /viewtopic.php?f=56&t=58703&p=481352#p481352 i will get this.Dear how can i check that my car power windows motor is compatible for auto fold.My car is RHD
As described
Thanks in advance.
I will try to study your case carefully, the problem is that I have no the diagrams of your Polo (IND) 'G' Model Year.
Edit (study)
1-The electrical installation for folding mirrors is the same as for Polo 6R Europe.
2- Central locking system ... About your BCM model and J386 TSG (driver door unit) I have no information, so you will have to try some codings...
BCM (new coding)
7AB02BBF48A10000013806006CAB069000C0414F608C2000200000000000
Subsystem 2 J386 (new coding)
000002
Remember to set the comfort function again in J386 and J387 after coding. Even if it already works.
Thanks, CNK told me a lot about your knowledge of the Polo 6Rciclo wrote:Ok, if you have problems with coding contact me.favi wrote:Thank you very much for Ciclo answer;) I ordered these motors have mentioned and we will be tested. If you do not work, then I stick to the installation of the K418.
govindsharma
Ciclo dear please ask me which type of information you required about Indian polo i will provide you.Dear one question about auto rain closing in polo 6R sometime it works perfectly and some time i will not why it happens.
JapFan
- Drives: Roomster 1.2 TSI DSG
Hello guys,
It’s been a while it’s me with the Roomster again
I completed the install of the RLS and BT. It’s all working great. However I cannot get automatic windows close by rain feature to work. But that is not such a big problem for me. Also the light sensor works I can see on the navigation switching to night mode. Maybe if someone could double check my coding but I think it should be OK.
Have a question regarding the AUTO lights I managed to get a new BCM almost for free it is 7H0 937 090B do you think it would be any good to make the upgrade to it???
Adding also the latest SCAN…
Address 01: Engine (J623-CBZB) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 HN HW: 03F 907 309 AK
Component: SIMOS10.22AH10 5493
Revision: --H10--- Serial number:
Coding: 00250056202400080000
Shop #: WSC 33361 790 00099
ASAM Dataset: EV_ECM12TFS02103F906070HN 004005
ROD: EV_ECM12TFS02103F906070HH.rod
VCID: 75E46048D4300DEA8D-8020
Readiness: 0110 0101
Part No SW: 0AM 300 061 T HW: 0AM 927 769 D
Component: GSG DSG AG7 431 5110
Revision: 00043014 Serial number:
Coding: 0000020
VCID: 3C72B56C7C9A9CA2B2-5102
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP90.clb
Part No SW: 6R0 907 379 AT HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0002
Serial number: --------------
Coding: 41DC487D212508C98219126D845510400905
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
ROD: EV_Brake1ESP90iBOSCH_VW25.rod
VCID: 102A31DCCB9248C23E-8044
Address 08: Auto HVAC (J255) Labels: 6Q0-907-044.lbl
Part No SW: 5J0 907 044 D HW: 5J0 907 044 D
Component: Climatronic H09 0103
Revision: K0000000
VCID: 2B5086304AF40B1A2B-807E
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R7 937 087 P HW: 6R7 937 087 P
Component: PQ25 BCM H30 0565
Revision: -1------ Serial number: --------------
Coding: 7A980BB848010000013806007C8B9EC000C0400F608C0000020010000000
Shop #: WSC 12345 123 12345
VCID: 51ACF4D8081801CA71-8004
Subsystem 1 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 260508 046 46 0204
Coding: 073025
Subsystem 2 - Part No SW: 6R0 959 801 AJ HW: 6R0 959 801 AJ Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 5240
Serial number:
Coding: 020000
Subsystem 3 - Part No SW: 6R0 959 802 AQ HW: 6R0 959 802 AQ Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 5240
Serial number:
Coding: 020000
Subsystem 4 - Part No SW: 5E0 919 719 F HW: 5E0 919 719 F
Component: E221__MFL-PR6 H05 0130
Serial number:
Coding: 820000
Subsystem 5 - Part No SW: 6R0 959 811 J HW: 6R0 959 811 J
Component: J388__TSG_HL 006 5240
Serial number:
Coding: 0A0000
Subsystem 6 - Part No SW: 6R0 959 812 J HW: 6R0 959 812 J
Component: J389__TSG_HR 006 5240
Serial number:
Coding: 0A0000
Address 10: Park/Steer Assist (J446) Labels: 5J0-919-475.clb
Part No SW: 5J0 919 475 HW: 5J0 919 475 A
Component: PARKHILFE 4K H11 0003
Coding: 100103
ASAM Dataset: EV_SK25XParkiAssis2 S01002
ROD: EV_SK25XParkiAssis2.rod
VCID: 72EE5B54A55E1AD2A8-8026
Component: VW10AirbagTB0 H10 0020
Revision: -------- Serial number:
Coding: 004230
ROD: EV_AirbaVW10BPAVW250_VW31.rod
VCID: 4A9EE3B4ED4E321230-801E
Serial number:
Serial number:
Part No SW: 5J0 920 841 G HW: 5J0 920 841 G
Component: KOMBI H04 0709
Coding: 110801
ROD: EV_Kombi_UDS_VDD_RM09_SK25.rod
VCID: 2E568F2471E67E320C-807A
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R7 937 087 P
Component: GW-K-CAN TP20 H30 0565
Revision: -1------
Coding: 832200
VCID: 70EA515CA35228C25E-8024
Component: IMMO H04 0709
Shop #: WSC 00000 000 00000
VCID: 6ADE43348D8ED21210-803E
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 G HW: 3T0 035 680 A
Component: RNS-MID H55 5238
Revision: AB001001 Serial number:
Coding: 04000402040000800000
VCID: 34629D4C97CA54E27A-8060
Subsystem 1 - Part No: 3T0 051 859 AM
Component: EU East V13 8350
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11220
Shop #: WSC 33361
VCID: 306A915CF7D268C21E-8064
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 N HW: 7P6 035 730 N
Component: TELEFON H16 4217
Revision: 1B001001 Serial number:
Coding: 0A00000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3D74B868AC8095AA85-8068
Coding: 0000020
Revision: K0000000
Coding: 073025
Serial number:
Coding: 020000
Serial number:
Coding: 020000
Serial number:
Coding: 820000
Serial number:
Coding: 0A0000
Serial number:
Coding: 0A0000
Coding: 100103
Coding: 004230
Serial number:
Serial number:
Coding: 110801
Revision: -1------
Coding: 832200
Coding: 11220
Shop #: WSC 33361
ROD: EV_UHVNA.rod
the bcm would be a good upgrade for sure. but you must remember that you need to re-do some of the wiring to accommodate the BCM Max functions.
it adds the auto light option and the possibility for OEM Xenon headlights too.
what do you exactly mean by 'automatic windows'?
JapFan
Hello iichel,
Sorry I meant rain closing... For the xenon's unfortunately there is no option for roomster but for the price I got the BCM automatic lights are enough upgrade.
Perhaps I can buy the adapter made by ciclo...But redo wiring if I get some diagram is no problem at all...
the wiring and manual by ciclo are well worth the price and the quality is usually excellent.
for rain closing, you can try to enable byte 0 bit 2 in your RLS
JapFan
thx will try ...
firegrafik
- Drives: 6R 1,6MPI(CFNA) sedan
Russian Volkswagen representatives from the factory in Kaluga. Released the Promo video concerning sales start the New Polo Sedan GT 1,4TSI CZCA 125HP
Because you have problems with codings in door units.govindsharma wrote:Ciclo dear please ask me which type of information you required about Indian polo i will provide you.Dear one question about auto rain closing in polo 6R sometime it works perfectly and some time i will not why it happens.
Anyway you changed the coding of the sensor:
Subsystem 1 - Part No: 5K7 955 559 B
Component: RLS 311215 03 37 0059
Coding: 036800
To: (you sent me by PM)
Coding: 0714DD
Please make a test with the two codings, and tell us which one it is right for rain closing in your 6R after you solved your coding problems in door units.
