Correct oil for GTI 1800 6c?
fivelittlefish
- Drives: 2016 GTI
I was wondering what is the correct spec oil for the new 1800 6c GTI - I've done about 2K miles and it needs a bit of a top up.
Thank you.
Thank you.
Re: Correct oil for GTI 1800 6c?
It should be written in your service book.
5w30 fully synthic castrol
fivelittlefish
- Drives: 2016 GTI
Thank you!
Castrol 0w30, all the Way. Unless you plan on the 20k service interval.
/ *L*
/ *L*
fivelittlefish
- Drives: 2016 GTI
Thank you.
See, this is why I'm confused - my service book lists the car as Q16, which is the flexible service interval.
So, which oil should I be putting in it to top up? TBH, I'm not that keen on going for 2 years with the same oil in it - I'll be asking for an oil change at 1 year. So should I top up with the 5w/30 or the 0w/30 ?
Quantum LongLife III 5W30 Fully Synthetic Engine Oil is the recommended VAG oil
Advertised on ebay for £25.91 inc delivery for 5l
If you know a friendly mechanic he can get the same from TPS- not sure about price (more cost effective getting 20l container)
Similar/same as 5W30 Castrol edge
mine also is stickered with q16 but ive got a service warning at 9k/ 11 months oldfivelittlefish wrote:Thank you.
Since the oil temperature in city driving easily exceeds 105 oC and the 5-30 is a thin oil, is there a reason to worry about oil becoming water in our warm designed Ea888? I am not so happy with the manual intervals as well and I plan on frequent changes...
Penarth Blues
- Drives: 2015 Polo GTI 5 door Black M6
I'm also on the long-life interval and my oil change light came on for about 12k. Garage said it didn't need changing but I went ahead and had the oil service anyway (£169!) as I'm not happy leaving the oil that long either. I'd put about 0.5 litre of oil in during the 12k I have done.
I also got them to update the software for the radio as it'd been playing up, and the handbrake had a lot of travel which was adjusted too. Overall I'm much happier it having been in, especially as it gives them a chance to make any 'unadvertised' updates where needed. It does feel better for the service, but that is probably just imaginary as it was going fine before it.
Rather that what oil. I'd be mote concerned about why oil.
Unless your engine runs at the limiter all day it shouldn't need oil that quick.
If you have checked the level properly, some can't. I'd be monitoring its use. Should not need filled after just 2000 miles
Penarth Blues
I meant to mention that too. It needs to be checked when warm - not cold. Read the handbook to find out how it should be read.WULLIE wrote:Rather that what oil. I'd be mote concerned about why oil.
green_comet
- Drives: 2016 Polo GTI
Any 5W30 fully synthetic oil that is 504/507 approved will be fine.
sbarker555uk
- Drives: gti
What is the correct service interval for the gti? Mine is year old and says I still have year to go for oil service? Is that right?
I did not realise there is long life interval as well on the 1.8 gti
Pretty certain the default service regime from the factory is flexible/long life, where the first oil change service is the sooner of 24 months or a maximum of 18,000.sbarker555uk wrote: Tue May 22, 2018 3:00 pm What is the correct service interval for the gti? Mine is year old and says I still have year to go for oil service? Is that right?
I had mine changed to time and distance as I have a service plan and I’m also a low mileage driver (time and distance is recommended by VW for low mileage owners). Under the service plan the service intervals are the sooner of 12 months or 10,000 miles.
http://www.volkswagen.co.uk/owners/servicing/regimes
