That looks very awesome, firegrafik. Can you find out the part numbers of the sensors and the receptor?
CNK
Drives: 6R
Post by CNK »
firegrafik wrote:Hello to everyone!
There is greatest news. The full type tyres pressure control (RKDS) is possible on Polo6R.
Eugene aka ZZZhuk is wisard
https://www.drive2.ru/l/461592849478059310/
Wow, great news! Now I know what I want to do when I finish the installation of HBA :lol:
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
iichel wrote:That looks very awesome, firegrafik. Can you find out the part numbers of the sensors and the receptor?
Zzzhuk answered, he will add the parts list to his report soon
WOW! Wonderful people.
Thanks Alexander.
Thank you very much Eugene, another good job. All that is to extend the safety in the driving are excellent modifications, this is definitely better than our TPMS.
Our dear CAN-dashboard (54-57 extended)...again... hehe! VCDS and ....? (It's hard for me to translate)
Michel, Szymon, without doubt this will be one of my next modifications.
Adam... it's a nice mod, what do you think? I think it would be good for our Big Brother T5/6. :)
The great 6R (PQ25) 8)
All the best
Fernando
firegrafik
ciclo wrote:...
There is an issue is to write to the control unit correct parameters for possible wheel sizes. There is software to create the parametric file, and it should be write to control unit by VagCanPro or ODIS-Engineering. The all possible issues you could learn on touran, passat forums with topics concerning RKDS.
ciclo wrote: Michel, Szymon, without doubt this will be one of my next modifications.
I would like to have it too. Already provided preliminary calculations for the cost.(250-300eur for used parts)
Anothe thing is to find someone with ODIS-Engineering.
The part numbers I guess:
Module, behind rear bumper: 3AA907273H
Holder module: 3AA907538
Sensors: 3AA907275F (these are the most expensive)
4-pin connector: 8E0971934A
Wiring:
T4/1 can dash high
T4/2 +12 terminal 30
T4/3 can dash low
T4/4 GND
This is an example from the passat CC 2014 (PQ35).
Adaptation per VCDS?
http://wiki.ross-tech.com/wiki/index.ph ... ecognition
firegrafik wrote:
ciclo wrote:...
OK.
I have the original VCP, but I still do not use it correctly. :?
Perhaps the VW dealership can make these adjustments, if necessary
Nothing is cheap ... :lol:
iichel wrote:The part numbers I guess:
Wiring:
T4/1 can dash high
T4/3 can dash low
T4/4 GND
Thank you very much. All information on this is welcome. :wink:
Alternative way.
:arrow: All info here
Bachecco
Drives: Polo 1.2
Post by Bachecco »
Hi ciclo, do you know the code of the new badge R-Line of golf 7 restayling? Image
Inviato dal mio iPhone utilizzando Tapatalk
firegrafik
I have talked to Eugene aka Zzzhuk. He wrote it could be possible to sell the used RKDS control units, reflashed with Polo's parametric firmware. Preliminary price is about 100 EUR, for one unit. To start preparing this series if the units, he needs to know:
1) the quantity of those wishing to this mod.
2)Also there is possible several wheel sizes to choose, so I ask you write what wheel sizes and pressures (from/rear) should be.
This is example
I would be in for this. :lol:
Bachecco wrote:Hi ciclo, do you know the code of the new badge R-Line of golf 7 restayling?
Not yet available in this ETKA online. Only R-modell. (R/L)
iichel wrote:I would be in for this. :lol:
+1
firegrafik, perhaps it would be better to open a new topic in the sales section, in this way everyone can write there the wheels data or required information.
On the other hand, would it be possible to get the control modules brand new? Example ... and, is it necessary to install the module in the bumper area?
Maybe it becomes a bit complicated if firegrafik opens a topic to sell the modules for Zzzhuk...
As I understood, one will be tested on a 'stock' MFA+ cluster. If it works, we can think about a bigger distribution.
firegrafik
Yes, iichel is right.
I will try it on my stock cluster at first, to be sure it works correctly , because Zzzhuk's cluster has modified firmware.
Locked
