How to upgrade your RCD-310 to a Sat-Nav RNS-310
Post Instructions on DIY modifications here - use all information with caution!
alexperkins
Site Admin
Re: How to upgrade your RCD-310 to a Sat-Nav RNS-310
Post by alexperkins »
Goodo. Should work fine there
It does sometimes take 20-30 mins to pick up a signal first time around
Is it currently in germany somewhere?
Bigtam
Drives: Polo GTI 2016
Post by Bigtam »
No bought it from a guy over on Briskoda and he is in Crawley and it comes up around that area
Bigtam
Post by Bigtam »
Thanks for your help Alex.Just checked the Nav and the unit cant see any satellites will check it tomorrow and see if it works then if not will buy a new GPS aerial.Do you know what coding I have to do for to get the mic working on the steering wheel.
alexperkins
Site Admin
Sounds like its definately not receiveing the satellites then. The connections are quite fragile on them - thankfully inexpensive to replace though.
Afraid not without looking. Itll be in the long coding helper on the radio settings i imagine.
Bigtam
Post by Bigtam »
Working now it was a dodgy GPS antenna
alexperkins
Site Admin
Happy days
Polo1971gti
Drives: Polo gti
Post by Polo1971gti »
Hi there links where to buy the microphone mine has never worked
Got to use my phone on loudspeaker when makin a call
My music does Bluetooth ok
