I obtained masses of info & help from a few other sites and from '2015_polo' on this forum.
The armrest I bought was (Ref1)
https://www.aliexpress.com/item/Free-sh ... 4be7653b34
The main advice came from (REf2)
http://www.team-bhp.com/forum/diy-do-yo ... ation.html
and (Ref3)
http://workshop-manuals.com/volkswagen/ ... h_armrest/
There are quite a few armrests from AliExpress but the supplier I chose had good reviews (assuming they were real) but was far from the cheapest. It arrived within 5 days via DHL and was well packaged.
![Image](http://i38.photobucket.com/albums/e127/hjgtiger/IMG_20170106_121736083_zpsnztfp1lf.jpg)
The fitting is a little involved as detailed in Ref2 where it is necessary to remove a lot of trim & console bits to enable lifting the rear end of the centre console to get the main alloy mount in position. I bought a cheap set of 'plastic trim prying tools' from eBay which made the job a lot easier and avoids damage/scratches.
This pic shows why so much has to be removed/loosened - the casting is sitting on top of the console afetr cuphlder removed
![Image](http://i38.photobucket.com/albums/e127/hjgtiger/IMG_20170106_143339621_zpsr4tqhdjf.jpg)
Ref2 shows that after removing most of the trim bits 2 horizontal screws holding the console. Mine did not have those screws fitted - I assume that this was intentional as there were no metal 'tags' for the screws to screw into.
![Image](http://i38.photobucket.com/albums/e127/hjgtiger/IMG_20170107_123301728_zpscejspjjl.jpg)
So this is the finished result
![Image](http://i38.photobucket.com/albums/e127/hjgtiger/IMG_20170107_144353628_zpstuexi1dn.jpg)
![Image](http://i38.photobucket.com/albums/e127/hjgtiger/IMG_20170107_144403910_zpshp8kvauz.jpg)
![Image](http://i38.photobucket.com/albums/e127/hjgtiger/IMG_20170107_144415940_zps1e2dposs.jpg)
![Image](http://i38.photobucket.com/albums/e127/hjgtiger/IMG_20170107_150637170_zpsyol4zckh.jpg)
