Kimd41, everything is solvable in case of faults. In the worst case, return to the previous state.
Btw, I have the control unit and airbag wiring (5K0) from my previous multifunction steering wheel (R model), in perfect condition. Maybe I could sell them to you (very cheap) in case you need them.
Both = 36€ + shipping - Spain - registered with tracking number 4,85€, payment by paypal.
Also, I'll give you three little presents that you'll need to install this MFSW, the two wires (+ and LIN) and the fuse.
Kimd41
Drives: 6R
Post by Kimd41 »
ciclo wrote:Kimd41, everything is solvable in case of faults. In the worst case, return to the previous state.
Ooooh that would be awesome man :D :D :D
Let's just wait for the wheel to arrive, I'll keep you updated. :wink:
Thanks and cheers.
Customize VCDS Autoscan
(Dedicated to a friend)
; created many moons ago :lol: (look in the Autoscan text file for better information)
CLICK HERE
Oh! yes...
My dear friend, the small adapter is a little joke, you already know me ... you can use it for whatever you want, you can even throw it away if it is your desire, the joke has fulfilled its mission ... :mrgreen:
Kimd41 wrote: Ooooh that would be awesome man :D :D :D
Thanks and cheers.
:wink:
prog-amateur
Drives: Polo 6R
Post by prog-amateur »
Dear Ciclo, CNK, thanks to both of you, I will read more and try to assemble it.
gti16
Drives: VW Polo 6r 1.6 TDI
Post by gti16 »
ciclo wrote:
gti16 wrote:I installed it clear :)
Negative pole and its connections. It appears on the auto scan but the battery light does not disappear.
Maybe it's a coding problem. Have you spoken with firegrafik or ZZZhuk?
There is no error in the modules, everything ok but the battery light does not turn off.
Will the alternator with LIN (LIN) be missing?
prog-amateur wrote:Dear Ciclo, CNK, thanks to both of you, I will read more and try to assemble it.
We are here if you need our help during installation. :wink:
Do a test: (engine OFF)
BCM:
- Enable Byte20 Bit3
- If coding is accepted, make an ignition cycle. (extract the keys from the ignition, etc ...)
- Return to the previous state if nothing happens. :mrgreen:
Post here VCDS scan. I think it will help the diviners, magicians, fortune tellers, geniuses and other specimens. :lol:
gti16
Post by gti16 »
Thank you, I'll test it tomorrow and then report the situation.
Image :lol:
Erwin updated (from-to) (T6)
Image :arrow: .....
gti16
Post by gti16 »
Ciclo
I do not have bit 3 in byte 20.
gti16 wrote:Ciclo
OMG Image... everyone has Bit3 in the Byte20. :lol:
Put here your BCM coding. Image
Adam87
Drives: T5.2
Post by Adam87 »
ciclo wrote: OMG... everyone has Bit3 in the Byte20
[emoji23][emoji23]
What is byte20 bit3 responsible for?
it indicates the presence of the LIN generator (alternator operated by the LIN databus)
Adam87 wrote: What is byte20 bit3 responsible for?
Adam87 wrote: [emoji23][emoji23]
:lol:
firegrafik, please, can you translate the 0 and 1 Bits? :wink:
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
ciclo wrote:firegrafik, please, can you translate the 0 and 1 Bits? :wink:
No problem.
Bit 0 Alternator with LIN bus installed
Bit 1 Battery/sensor with LIN bus installed
Locked
