However, New BCM coding*: (copy and paste from here)
35B029BF08E324009A280D916C6B9DD15A40472F600D10D0200000030000
Take a look at this guide (20 point) just to learn how to copy the new BCM coding from here and paste it.
*Activated functions in this new BCM coding
- Coming Home.
This function is possible because it is semiautomatic and does not require the light sensor.
How does it work
- And the following functions.
viewtopic.php?f=56&t=58703&start=195#p477710
viewtopic.php?f=56&t=58703&start=765#p491539
viewtopic.php?f=56&t=58703&start=765#p491577
Once you enter the new coding, Autoscan ---> Gateway installation list ---> Clear all DTC's ---> Done .... wait for the new reading of Gateway installation list ---> click Start (new Autoscan) ---> Save it ---> Post here.
Check all lights and new features.
Automatic lights and Leaving Home require the light sensor. Leaving Home function is automatic.
You need to install the light sensor, but this is the kit that is installed by everyone (around the world) on their Polo 6R.
- Dimming mirror
- Rain Light Sensor
- Wiring
- And switch with AUTO function
Useful link
Once this kit is installed, you can install my wiring for automatic lights. Here the sale
With all this information you have saved an infinite amount of time and money. But let's continue...
You do not have cruise control, hmm... a GTI without CCS? OMG ... buy these stalks 'in this store'
It will be necessary to change the ring (for models without ESP) by your current one (for models with ESP,...very easy to do). The ring of the sale is not valid for your GTI, but this is the cheapest way to get CCS for your GTI. It will also be necessary to make a slight modification to the wiring of the sale, but I will send you the necessary when you buy my wiring of automatic lights.
