Hi I've just purchased a blackvue camera which I'm going to install over the weekend can anyone tell me what's the best way to hard wire it into the fuse box and what fuse to use.....thanks
i wired mine into the 12v cig lighter fuse, with an adapter that came with my next base dash cam. i ran the wire without removing any trim. You should find that you can pull the rubber trim round the door away enough to push the cable in.
the hardest bit was getting the cable through a small hole that was already in the fuse box (under the steering wheel, just pull off the panel).
MczZippy wrote:i wired mine into the 12v cig lighter fuse, with an adapter that came with my next base dash cam. i ran the wire without removing any trim. You should find that you can pull the rubber trim round the door away enough to push the cable in.
i can sort photo's if you need them.
Thanks mczZippy could you sort them out if you don't mind I'm not very good at doing stuff like this cheers
Interesting. I leave my dash cam cable dangling over the touchscreen and it gets in the way.
I'd like photos please
You can buy a kit off eBay so you don't have to use the 12 volt cig charger, I'm putting my cam next to my rear view mirror and using the interior light as its power source
just get a couple of 5A fuses of the size you have and stick them in the ones for your dash cams (i'm guessing you have separate supply for front and rear cams)
