Led rear light bulbs
Vasey
Drives: Polo gt bluemotion
Post by Vasey »
Hi to everyone I'm in the process of changing some bulbs on my blue gt to led,so far I've changed the DRL and the reverse light with no problems so I purchased some more of the same bulb for the rear brake lights when I change 1 everything is fine but when I go to change the opposite side the error bulb light come on... These bulbs are the Samsung 3623 Gold canbus led 5000k any ideas guys many thanksImageImageImage
FerhaTopaLGT
Drives: BlueGT
Re: Led rear light bulbs
Post by FerhaTopaLGT »
Vasey wrote:Hi to everyone I'm in the process of changing some bulbs on my blue gt to led,so far I've changed the DRL and the reverse light with no problems so I purchased some more of the same bulb for the rear brake lights when I change 1 everything is fine but when I go to change the opposite side the error bulb light come on... These bulbs are the Samsung 3623 Gold canbus led 5000k any ideas guys many thanksImageImageImage
İ can help you but if you got Vagcom
Tapatalk kullanarak iPhone aracılığıyla gönderildi
Vasey
Post by Vasey »
Tapatalk kullanarak iPhone aracılığıyla gönderildi[/
Vasey
Post by Vasey »
Haven't got vagcom yet, can you turn the canbus error of with vagcom?
FerhaTopaLGT
Drives: BlueGT
On The beş Polo you can turn every error off you Sony Ege'n need a canbus lamps
d-ash
Drives: 6C 2016 R-Line 1.2 90PS - Blue Silk
Post by d-ash »
Perhaps one of the LED bulbs is faulty. Have you tried the one which works in the other side to see if one rear light assembly is causing the error code?
Alternatively, the ballast of the 2 LEDs combined may not be enough to prevent the error (whereas one LED plus one filament bulb provide just enough resistance to prevent the error code). Might be worth trying a different type of LED. See my reversing lights topic for the ones I used https://www.uk-polos.net/viewtopic.php?f=56&t=69450. Also from HIDs Direct.
Vasey
Post by Vasey »
d-ash wrote:Perhaps one of the LED bulbs is faulty. Have you tried the one which works in the other side to see if one rear light assembly is causing the error code?
That's where I purchased them from hids direct tried swapping them over but it's just the same
FerhaTopaLGT
Drives: BlueGT
Just use vcds and cancel the error
Vasey
Post by Vasey »
It's working with 1 brake led in but as soon as I change the other 1 the fault comes on but it's ok with just the 1 led in either side
d-ash
Post by d-ash »
Looking at your photos I'm sure mine is a different brand to yours, and might have a different ballast. Don't know whether HIDS Direct have sufficient info to advise resistances on the different types of LED they import to help in your choice.
You're welcome to try my spare if you're nearby (Darlington). If that works without error while one of your current LEDs is in the other side then you'll need a pair of the type I used.
PM me if you're close enough to visit
Dave
Dink
Drives: 2015 GTI
Post by Dink »
you are better off using non can-bus friendly LED's and switching off the error
as the way they get around the can-bus is they put a little resistor across the supply, but they are always under sized and get VERY hot.
Vasey
Post by Vasey »
Dink wrote:you are better off using non can-bus friendly LED's and switching off the error
Just been to a garage who has vagcom they said they can switch the error of but it will come back on when you restart the car is this true? He said it's constantly checking the system so you cant permanently switch it off
peter_dk25
Drives: Blue GT
Post by peter_dk25 »
No, it is not true.
You can choose which bulbs you want the system to check.
It is done by using VCDS - 09 - long coding......
Vasey
Post by Vasey »
peter_dk25 wrote:No, it is not true.
So Peter can you knock all the canbus of so I could change every bulb on the car to led and no warning light will come on
FerhaTopaLGT
Drives: BlueGT
On the new brain you can code every light no problem ;) but not from long coding you need to code over adaptation [emoji106] what Peter wrote is not long coding its adaptation
