Instrument cluster
Instrument cluster
Hi there!
I have a 2011 1.2 TSI Polo. I am looking to update the instrument cluster as find it very frustrating not knowing the engine temperature.
I have found a second hand one on Ebay but am wondering is it fairly easy to recode to my car?
Thanks!
Sent from my iPhone using Tapatalk Pro
Thanks!
Re: Instrument cluster
Hi chrispy
6C IC is not compatible for 6R. Don't buy it.
I just noticed that
Strange that the 6R ones are £500!
If I was to get my hands on a 6R one with the temperature dials.. how easy are they to install?
Hi Chrispy
These clusters are quite rare now, specially on the secondhand market.
Plus if your trying to buy a new one from a VW Dealer, they would require like for like swap.
Meaning it has to be the same part number, for example MFA+ part number other wise Volkswagen charge a surcharge which can end up just shy under £1000.00 for new cluster uncoded.
Additional labour cost for the dealer to code the unit for you or a specialist is slightly cheaper.
You will need to have special software, to access and transfer your immobilizer data, mileage, sync keys etc from your old cluster to the new one.
VCDS will not able to do this.
If your looking for a rare highline MFA+ VW Polo 6R cluster, I have one for sale MPH UK version and can transfer all data from your old cluster to the new one.
PM for more information
Hi JIC
I would love the Highline IC however I have seen your ones online and sadly I do not have the money you are asking for
I was hoping the £100 one would work
it's impossible:chrispy. wrote:I was hoping the £100 one would work
PS. I also often regret that used parts from Polo 6C are cheaper than from the 6R..
Hi Chrispy
As CNK and others have said on this forum, 6C cluster is not compatible with older 6R model Polos.
6C cluster would have been a great upgrade, on a older 6R but the 6C cluster is totally different in terms of electronics.
But might have a solution to your problem chrispy , send me a PM I will explain in detail
That's cool! I understand the £100 6C one wont work think I wanted it to because of the price.
Not a problem
Not a problem
JIC Cracked wrote:Hi Chrispy
Hi!
Sorry to steal this post, but if JIC Cracked has some great solution for me too, I would like nice PM too
I would like to have blue gt or gti cluster too for my polo... kmh version
Hi Pave
I have sent you PM, please check your inbox.
- Drives: Lowered Polo 6R
Can I get a PM too?? 6R 2009 with currently broken instrument cluster, would love engine temp etc
Hi Edward
Hello JIC Cracked,
Can you help me with upgrading the cluster of my 6R ,with cluster from 6C
chrispy.
Do you manage to retrofit cluster from 6c to 6r? Is it possible with new wiring?
- Drives: 6R
Can you help me with transfer data from toledo cluster to polo 6r?JIC Cracked wrote: ↑Mon Mar 06, 2017 1:19 pm Hi Chrispy
