Benji58 - Polo 6R TDI 75 - R-Line Conversion
CNK
Drives: 6R
Re: Benji58 - Polo 6R TDI 75 - R-Line Conversion
Post by CNK »
Very nice Polo! :wink:
Really tasteful OEM mods. I think the Golf ED35 Watkins Glen style wheels really suit the Polo. 8)
benji58 wrote:Hello everybody !
Awesome ... I'm speechless, trying to be less emotional and more rational.
(...have been some years since we met in the French forum...)
Excellent JOB! Step by step. (effort, will, the money, time, etc...)
Your 6R R-line it's awesome. 8) Enjoy it!
Maybe you'll never forget this car. :)
Norbreck21a
Post by Norbreck21a »
I think you are the first person I've ever seen that's done a manual to automatic climate control conversion. That must have been a nightmare with all the sensors and vent motors etc ? Was it a dash out job ?
Cool car by the way - very tasteful.
CNK
Drives: 6R
Post by CNK »
Norbreck21a wrote:I think you are the first person I've ever seen that's done a manual to automatic climate control conversion. That must have been a nightmare with all the sensors and vent motors etc ? Was it a dash out job ?
You forgot about @iichel ;)
benji58
Drives: 6R R-Line 1.2 TDI
Post by benji58 »
CNK wrote:Very nice Polo! :wink:
SRGTD wrote:Really tasteful OEM mods. I think the Golf ED35 Watkins Glen style wheels really suit the Polo. 8)
Thank you ! :D
ciclo wrote:Awesome ... I'm speechless, trying to be less emotional and more rational.
Thanks a lot ciclo!
It's on I will never forget this car, after all this time passing on, to him added options, again and again ... :D
Yes CNK reason iichel did it also !
Conversion is mostly patient and meticulous. It took me 3 working days (disassembling the entire dashboard and the heating block, modified wiring ...)
But now I am very happy everything works perfectly and I have no VCDS error :arrow: OEM :D
dash out... cross member out... not an easy job for sure
benji58
Post by benji58 »
News for my polo :mrgreen:
-Install folding mirrors OEM
-Upgrade BCM to 7E0937090B
And installation RDKS :arrow: work in progress
Ciclo helps me a lot right now to make this work :twisted:
Ash6R
Drives: Polo 1.2 TSI SEL
Post by Ash6R »
How much did it cost to get the R line body kit?
Car looks awesome btw :D
benji58 wrote:And installation RDKS :arrow: work in progress
I'm working on it (very interesting 8)).
benji58
Post by benji58 »
Ash6R wrote:How much did it cost to get the R line body kit?
Thanks !
For the price I will not tell you exactly, I no longer count :lol: . It is necessary to count approximately 500€ of used part + price of the painting + grill ...
ciclo wrote:I'm working on it (very interesting 8)).
Thank you for your precious help, it is not simple for me this mod :roll:
benji58
Post by benji58 »
Hello everyone
I'm asking for your help. To all the professionals of the polo 6R :D
I installed RDKS, but this one does not work .. (I can not find any solution)
My problems :
- No display on the cluster
- RDKS module does not recognize valves
My installation:
- RDKS Module 3AA907273F
- Valves RDK 5Q0907275B
- + 12V on terminal 30
- Can Lines on the powertrain
I tried to connect the CAN line on the IC, still no display on the cluster and an error communication in the gateway...
Where can my problem come from? Coding? RDKS module not compatible / failing? Incompatible cluster software? .... :?:
My autoscan:
Type chassis: 6R (7E0)
Scanner: 01 03 08 09 10 15 17 19 25 37 44 47 55 56 65 0B
VIN: WVWZZZxxxxxxxxxxx   Kilometrage: xxxxkm
01-Moteur -- Etat: OK 0000
03-Freins ABS -- Etat: OK 0000
08-Climatronic -- Etat: OK 0000
09-Centrale Elec. -- Etat: OK 0000
10-Assistance stationnt -- Etat: OK 0000
15-Airbags -- Etat: OK 0000
17-Instruments -- Etat: Défaut 0010
19-Gateway CAN -- Etat: OK 0000
25-Anti-démarrage -- Etat: OK 0000
37-Navigation -- Etat: OK 0000
44-Direction assistée -- Etat: OK 0000
47-Sonorisation -- Etat: OK 0000
55-Portée des feux -- Etat: Défaut 0010
56-Radio -- Etat: OK 0000
65-Pression pneus -- Etat: Défaut 0010
Adresse 01: Moteur (J0000-CFWA)       Labels: 03P-906-021-CFW.clb
   No. pièce Log: 03P 906 021     Mat: 03P 907 425 A
   Pièce: R3 1.2 DCM3.7 H08 9505
   Révision: 11003001    No. de série:
   Codage: 00114014002400080000
   No. Atelier: WSC 00000 000 00000
   Jeu de données ASAM: EV_ECM12TDI03103P906021 001016
   ROD: EV_ECM12TDI03103P906021.rod
   VCID: 65C03E9B64A7E3697A-8030
Aucun code défaut trouvé.
Tests passés: 0000 0000
Adresse 03: Freins ABS (J104)       Labels: 6R0-907-37x-ABS82.clb
   No. pièce Log: 6R0 907 379 AE    Mat: 6R0 907 379 AC
   Pièce: ABS8.2 front  H04 0001
   Révision: --------
   Codage: 200224E3016F00BB042824E980D700000000
   No. Atelier: WSC 00788 648 00255
   VCID: 01080A0B9CCF2F49E6-8054
Adresse 08: Climatronic (J255)       Labels: 6R0-907-044.clb
   No. pièce Log: 6R0 907 044 H    Mat: 6R0 907 044 H
   Pièce: Climatronic   H11 0812
   Révision: V0000000
   VCID: 387EA7EF8B95AE8111-806C
Adresse 09: Centrale Elec. (J519)       Labels: 7E0-937-BCM-V1.clb
   No. pièce Log: 7E0 937 090 B    Mat: 7E0 937 090
   Pièce: BCM PQ25 Max4 H81 0744
   Révision: B9081001    No. de série: 0982 259160361
   Codage: 3CB029BF48E1240093280E917CEB97D05A80672F608D30C1200000030000
   No. Atelier: WSC 02737 790 12345
   VCID: 2A5A8DA745390C1197-807E
   Sous-système 1 - No. pièce: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Pièce: RLS 161014 05  54  0403
   Codage: 06302D
   Sous-système 2 - No. pièce Log: 6R0 959 801 CE    Mat: 6R0 959 801 CE  Labels: 6R0-959-801.CLB
   Pièce: J386__TSG_FT  003 9612
   No. de série: KU0KU005051551253047
   Codage: 0200A3
   Sous-système 3 - No. pièce Log: 6R0 959 802 CJ    Mat: 6R0 959 802 CJ  Labels: 6R0-959-802.CLB
   Pièce: J387__TSG_BT  003 9612
   No. de série: KU0KU005051551250425
   Codage: 1000AB
   Sous-système 4 - No. pièce: 1K8 951 171 A
   Pièce: DWA-Sensor 00  001 0103
   Codage: 000000
   Sous-système 5 - No. pièce: 1K0 951 605 C
   Pièce: LIN BACKUP HO  H05 1501
   Codage: 000000
   Sous-système 6 - No. pièce: 1K8 951 171 A
   Codage: 000000
   Sous-système 7 - No. pièce Log: 5K0 959 542 B    Mat: 5K0 959 542 B
   Pièce: E221__MFL-TAS  H30 0036
   No. de série: 0113742
   Codage: 820000
Adresse 10: Assistance stationnt (J446)       Labels: 7E0-919-475.clb
   No. pièce Log: 7E0 919 475 J    Mat: 7N0 919 475
   Pièce: PARKHILFE 8K  H06 0105
   Révision: --------    No. de série: 28261224902578
   Codage: 308001
   No. Atelier: WSC 02756 790 50316
   Jeu de données ASAM: EV_VW75XParkAssis8K 001003
   ROD: EV_EPHVA18VW250GPCS.rod
   VCID: 3978A2EBB89FB789EE-806C
Adresse 15: Airbags (J234)       Labels: 5K0-959-655.clb
   No. pièce Log: 6R0 959 655 K    Mat: 6R0 959 655 K
   Pièce: VW10Airbag01K H09 0020
   Révision: --------    No. de série: 003GX00XLZLX
   Codage: 00314B
   Jeu de données ASAM: EV_AirbaVW10BPAVW250 A01001
   VCID: 4A9AED27ED792C1177-801E
   Capteur de collision du sac gonflable latéral: côté conducteur:
   No. de série: 3575HRB405T0U20SAHVG
   Capteur de collision de sac gonflable latéral: côté passager:
   No. de série: 3585HRB405T0U20S2OJ4
   Capteur de collision du sac gonflable latéral AR: côté cond.:
   No. de série: 3515RRB405V0R8ACI0O3
   Capteur de collision du sac gonflable latéral AR: côté pass.:
   No. de série: 3525RRB40630Q8K49PJW
Adresse 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   No. pièce Log: 6R0 920 870 B    Mat: 6R0 920 870 B
   Pièce: KOMBI         H05 0607
   No. de série: 00000000000000
   Codage: 140E01
   No. Atelier: WSC 12345 123 12345
   Jeu de données ASAM: EV_Kombi_UDS_VDD_RM09 A04716
   VCID: 346693DF9FFD4AE13D-8060
1 Code défaut trouvé:
12658432 - Fonctionnement limité en raison de l'absence de message
          U1111 00 [008] - -
          Intermittent - Confirmé - Testé depuis RàZ mémoire
             Capture:
                    Etat du défaut: 00000001
                    Priorité du défaut: 6
                    Fréquence du défaut: 1
                    Compteur de RAZ: 80
                    Kilometrage: xxxx km
                    Date: 2017.05.08
                    Temps: 19:16:39
Adresse 19: Gateway CAN (J533)       Labels: Aucun
   No. pièce Log: 7E0 909 901     Mat: 7E0 937 090
   Pièce: GW-K-CAN TP20 H81 0744
   Révision: B9081001
   Codage: 002000
   VCID: 68DE37AF9BB5FE0141-803C
Adresse 25: Anti-démarrage (J334)       Labels: 5K0-920-xxx-25.clb
   No. pièce Log: 5K0 953 234     Mat: 5K0 953 234
   Pièce: IMMO          H05 0607
   Codage: 000000
   Jeu de données ASAM: EV_Immo_UDS_VDD_RM09 A03709
   VCID: 6ADA4DA78DB9CC1157-803E
Adresse 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   No. pièce Log: 1T0 035 680 P    Mat: 1T0 035 680 P
   Pièce: RNS-MID       H10 5270
   Révision: AB001001    No. de série: VWZ6Z7N6370477
   Codage: 04070040000000810001
   VCID: 3B74B8E3BAA38599FC-806E
   Sous-système 1 - No. pièce: 1T0 919 859 B
   Pièce: EU West V14  8477
Adresse 44: Direction assistée        Labels: 6Q0-423-156.clb
   No. pièce: 6R0 423 156 B
   Pièce: LenkhilfeTRW        V277
   Codage: 10130
   VCID: 2F6C9CB3EADB693940-807A
Adresse 47: Sonorisation (R12)       Labels: 5K0-035-456.clb
   No. pièce Log: 5K0 035 456     Mat: 5K0 035 456
   Pièce: KonzernAmp 8K 0340
   Révision: --------    No. de série: BP218109097291
   Jeu de données ASAM: EV_AudioVerst8KanalBNO1 A01003
   ROD: EV_AudioVerst8KanalBNO1.rod
   VCID: 67DC34939EABF17948-8032
Adresse 55: Portée des feux (J431)       Labels: 6R0-907-357.clb
   No. pièce Log: 6R0 907 357     Mat: 6R0 907 357
   Pièce: LWR-ECU       H02 0070
   Révision: --------    No. de série: --------------
   Codage: 0112000001000000
   Jeu de données ASAM: EV_HeadlRegulVWLWRPt 001004
   VCID: 77FC64D3CE0B61F9D8-8022
13705474 - Bus de données
          U1121 00 [137] - message manquant
          Témoin allumé - Confirmé - Testé depuis RàZ mémoire
             Capture:
                    Compteur de RAZ: 39
                    Date: 2017.05.08
                    Temps: 00:04:41
Adresse 56: Radio (J0506)       Labels: 1T0-035-680.clb
Adresse 65: Pression pneus (J502)       Labels: 3AA-907-273.clb
   No. pièce Log: 3AA 907 273 F    Mat: 5Q0 907 273
   Pièce: RDKBERU30     H04 0011
   No. de série: 40000000043140
   Jeu de données ASAM: EV_RDKBERU30 005005
   ROD: EV_RDKBERU30_VW51.rod
   VCID: 377CA4D38E8BA1F918-8062
8398082 - Capteur(s) de pression de pneus
          C111A 31 [009] - Aucun signal
             Capture:
                    Priorité du défaut: 3
                    Compteur de RAZ: 40
                    Date: 2017.05.08
                    Temps: 19:10:53
                    Vitesse du véhicule: 32 km/h
                    Température extérieure: 12.5 °C
                    Niveau de réception antenne 1: 540 mV
                    Niveau offset antenne 1: 270 mV
thank you in advance
6RPotentialBuyer
Drives: Candy White Polo 6R
Post by 6RPotentialBuyer »
Really nice mods dude! How are you sourcing all of these parts though?? I've been searching for ages for an R line conversion and the gloss black interior trim but they just don't come up for sale :( Where do you buy your parts from??
benji58 wrote: Where can my problem come from? Coding? RDKS module not compatible / failing? Incompatible cluster software? ....
The problem lies in the RDKS unit, does not receive signals from the sensors/valves, or sends signals to the IC.
Try to configure the adaptation channels again with VCDS.
Try also with the file that I sent you for VCP.
Maybe firegrafik or rdasadia can enlighten us about it.
Btw, you should install this sensor for your Bixenon headlights - Static Cornering Lights.
viewtopic.php?f=56&t=69603&start=15#p520005
Read the installation guide on that topic. :wink: (better read the whole topic)
