rcd310 to rcd510 straight swap ? or need vcds coding.
tommytse22
Drives: polo gti
Post by tommytse22 »
hello, currently swamped my rcds 310 to a rcd510. however i keep hearing a strange beeping/bell noise when i turn car off or whenever i lock the car. i believe it is coming from the speakers and it is the radio?
i read somewhere the noise is telling me there is a short abd draining battery if im correct? it is only ever after the radio replace im hearing this? does this mean i need to code the radio or nothing to do with the radio.
thank you.
joe6
Drives: Golf Mk6 GTI (Scirocco gone) Polo 6c GTI
Re: rcd310 to rcd510 straight swap ? or need vcds coding.
Post by joe6 »
It depends on the age of the car. It does not normally need any coding - should be plug and play. Battery drain can happen on early models (not sure of dates) and needs a replacement CAN gateway and VCDS coding. You would know if you had battery drain as it flattens the battery quite quickly. Not sure what the noise is. Not heard that before when doing the swap.
samehtolba
Drives: 6R
Post by samehtolba »
Hi
Where to be original RCD510
samehtolba
Drives: 6R
What are the differences between RCD & RNS510
Jessesam
Drives: BlueGT
Post by Jessesam »
RNS is sat nav version
samehtolba
Drives: 6R
Jessesam wrote:RNS is sat nav version
you mean RCD vs is RNS is GPS only?
Jessesam
Drives: BlueGT
Post by Jessesam »
the main difference is Sat Nav but their are others
alexperkins
Site Admin
Post by alexperkins »
Rns510 is very different to the rcd510. Main differences are higher res screen, sat nav, built in hard drive, faster processor, reverse camera support to name but a few
Willni
Drives: Polo '14 6R, Golf 07' Edition 30
Post by Willni »
In a polo 6r you're fine, no coding requires and the 6c is a different platform.
