MOT rear imbalance
piglet14
Drives: Arosa
MOT rear imbalance
Post by piglet14 »
Dismal failure.
Down on one side which could be a sticking wheel cylinder but we did all that just a few months ago.
Do the load adjusters play up, and can that cause imbalance?
Ta
alexperkins
Site Admin
Re: MOT rear imbalance
Post by alexperkins »
They generally behave. Could be a sticking shoe against the drum
Presume this is braking vs handbrake
piglet14
Drives: Arosa
Post by piglet14 »
Believe it to be foot brake only.
If the compensators are generally good I'll start with the obvious.
Especially given that compensators are 80 quid!
Can they be stripped?
alexperkins
Site Admin
yeah, you can easily strip the rear drums down and clean it all up. Scuff the shoes and drum lining with some course sandpaper. Bleed the rear brake lines too just in case there is air in the pipes.
piglet14
Drives: Arosa
Post by piglet14 »
No, I mean can the compensators be stripped? :lol:
alexperkins
Site Admin
No. It's a bin job and replace
GSF have 55% off this weekend if they stock it, let me know and I'll send you the code so you can reserve/order it online
piglet14
Drives: Arosa
Post by piglet14 »
Tried adjusting shoes, no difference.
Pair of new VW branded!!!! cylinders on their way (Ebay bargain)
Failing that it's time to cough for a compensator.
piglet14
Drives: Arosa
Post by piglet14 »
Fixed, passed. Wasn't compensator.
alexperkins
Site Admin
Excellent. Wheel cylinders then?
piglet14
Drives: Arosa
Post by piglet14 »
Yup
Not very old either.
