For the RDKS system it put me on an idea. My valves may not be compatible with the module
Benji58 - Polo 6R TDI 75 - R-Line Conversion
Re: Benji58 - Polo 6R TDI 75 - R-Line Conversion
Thank you for all this information ciclo, so now I think later installed the steering wheel sensor G085
Yes, it is likely.
Ask to rdasadia what type of valves/sensors has installed.
What have you finally done with the valves/sensors?
I ordered new valves/sensors 3AA907275F
I'm waiting for them to try
It has to work because I bought them too ...
Yes I have finally decided to install this system.
I installed the new valves 3AA907275F, One problem is solved, the valves are detected by the RDKS module. I have the pressure displayed in the 08 measuring blocks in vcds.
BUT ! always the error and no display on the cluster...
1 Code défaut trouvé:
12658432 - Fonctionnement limité en raison de l'absence de message
U1111 00 [008] - -
Intermittent - Confirmé - Testé depuis RàZ mémoire
Capture:
Etat du défaut: 00000001
Priorité du défaut: 6
Fréquence du défaut: 1
Compteur de RAZ: 80
Kilometrage: xxxx km
Date: 2017.05.08
Temps: 19:16:39- iichel
Complete autoscan in English please ?
here it is my full autoscan in English :
Chassis Type: 6R (7E0)
Scan: 01 03 08 09 10 15 17 19 25 37 44 47 55 56 65 0B
VIN: WVWZZZ6RZCY129376
47-Sound System -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine (J0000-CFWA) Labels: 03P-906-021-CFW.clb
Part No SW: 03P 906 021 HW: 03P 907 425 A
Component: R3 1.2 DCM3.7 H08 9505
Revision: 11003001 Serial number:
Coding: 00114014002400080000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_EMC12TDI03103P906021 001016
ROD: EV_ECM12TDI03103P906021.rod
VCID: 65C03E9B64A7E3697A-8030
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ABS82.clb
Part No SW: 6R0 907 379 AE HW: 6R0 907 379 AC
Component: ABS8.2 front H04 0001
Revision: --------
Coding: 200224E3016F00BB042824E980D700000000
Shop #: WSC 00788 648 00255
VCID: 01080A0B9CCF2F49E6-8054
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0812
Revision: V0000000
VCID: 387EA7EF8B95AE8111-806C
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 259160361
Coding: 3CB029BF48E1240093280E917CEB97D05A80672F608D30C1200000030000
Shop #: WSC 02737 790 12345
VCID: 2A5A8DA745390C1197-807E
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 161014 05 54 0403
Coding: 06302D
Subsystem 2 - Part No SW: 6R0 959 801 CE HW: 6R0 959 801 CE Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 9612
Serial number: KU0KU005051551253047
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 CJ HW: 6R0 959 802 CJ Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 9612
Serial number: KU0KU005051551250425
Coding: 1000AB
Component: DWA-Sensor 00 001 0103
Component: LIN BACKUP HO H05 1501
Subsystem 7 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B
Component: E221__MFL-TAS H30 0036
Serial number: 0113742
Coding: 820000
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 J HW: 7N0 919 475
Component: PARKHILFE 8K H06 0105
Revision: -------- Serial number: 28261224902578
Coding: 308001
Shop #: WSC 02756 790 50316
ROD: EV_EPHVA18VW250GPCS.rod
VCID: 3978A2EBB89FB789EE-806C
Component: VW10Airbag01K H09 0020
Revision: -------- Serial number: 003GX00XLZLX
Coding: 00314B
ASAM Dataset: EV_AirbaVW10BPAWV250 A01001
VCID: 4A9AED27ED792C1177-801E
Subsystem 1 - Serial number: 3575HRB405T0U20SAHVG
Subsystem 2 - Serial number: 3585HRB405T0U20S2OJ4
Subsystem 3 - Serial number: 3515RRB405V0R8ACI0O3
Subsystem 4 - Serial number: 3525RRB40630Q8K49PJW
Part No SW: 6R0 920 870 B HW: 6R0 920 870 B
Component: KOMBI H05 0607
Coding: 140E01
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_Kombi_UDSV_DD_RM09 A04716
VCID: 346693DF9FFD4AE13D-8060
1 Fault Found
12658432 - Function Restricted due to Missing Message(s)
U1111 00 [008]
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 11
Reset counter: 103
Mileage: 112449 km
Date: 2017.05.22
Time: 22:09:56
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 002000
VCID: 68DE37AF9BB5FE0141-803C
Component: IMMO H05 0607
ASAM Dataset: EV_Immo_UDS_VDDR_M09 A03709
VCID: 6ADA4DA78DB9CC1157-803E
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 P HW: 1T0 035 680 P
Component: RNS-MID H10 5270
Revision: AB001001 Serial number: VWZ6Z7N6370477
Coding: 04070040000000810001
VCID: 3B74B8E3BAA38599FC-806E
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V14 8477
Address 44: Steering Assist Labels: Redir Fail!
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 10130
Shop #: WSC 00788
VCID: 2F6C9CB3EADB693940-807A
Address 47: Sound System (R12) Labels: None
Part No SW: 5K0 035 456 HW: 5K0 035 456
Component: KonzernAmp 8K H06 0340
Revision: -------- Serial number: BP218109097291
ASAM Dataset: EV_AudioEvrst8KanalBNO1 A01003
ROD: EV_AudioVerst8KanalBNO1.rod
VCID: 67DC34939EABF17948-8032
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
ASAM Dataset: EV_HedalRegulVWLWRPt 001004
VCID: 77FC64D3CE0B61F9D8-8022
1 Fault Found
13705474 - Databus
U1121 00 [137] - Missing Message
Fault Priority: 6
Fault Frequency: 1
Reset counter: 39
Mileage: 112449 km
Date: 2017.05.22
Time: 22:09:56
Address 56: Radio (J0506) Labels: None
Address 65: Tire Pressure (J502) Labels: None
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000043140
ASAM Dataset: EV_RDKBEUR30 005005
ROD: EV_RDKBERU30_VW51.rod
VCID: 377CA4D38E8BA1F918-8062
End---------------------(Elapsed Time: 03:36, udsna)-----------------------
ah very good. what I would suggest probably is the removal of the ABS based TPMS. Unfortunately I don't know the coding for ABS, only ESP8.2 and ESP 9.0. Maybe @firegrafik could help out. He is from the Russian Polo community where replacing ABS in favour of ESP is done regularly.
It was already done.iichel wrote: Tue May 23, 2017 7:36 am ah very good. what I would suggest probably is the removal of the ABS based TPMS. Unfortunately I don't know the coding for ABS, only ESP8.2 and ESP 9.0. Maybe @firegrafik could help out. He is from the Russian Polo community where replacing ABS in favour of ESP is done regularly.
The problem may be in the IC software.
rdasadia has a software updated compared to yours, and Eugene (aka ZZZhuk)...hmm... has a software in his IC from T5 (magic things)
And that's the reason I think the problem is the IC software. Of course, it's all speculation.
The autoscan of rdasadia is our best bet.
Did you already adapt the sensors to the module?
http://wiki.ross-tech.com/wiki/index.ph ... ecognition
@iichel, the pressures are already recognizable in MBs.
@benji58
To generate the tire pressure settings (according to the pressures table on fuel filler flap) use this application (for ODIS, VCP or Binary):
http://htmlpreview.github.io/?https://r ... rator.html
eg, this is the tire pressure table in my fuel filler flap/cap. 1.2 TSI (215/40 R17):
Enable 'Individual' for customize your tire pressures, or enable more tire sets.
examples: 215/35 R18, Sport mode, Path of rabbits, etc...
@benji58
thank you for your replies
iichel : TPMS indirect is already disabled in ABS module.
The adaptation of the sensors took place automatically while driving. If I go to the measuring units in the RDKS module, the ID of the sensors is indicated in all the wheels and the live pressure is displayed.
ciclo : I have already tried to set up my RDKS module, but when I launch the update with VCP it marks me communication error ...
How can I update my IC software?
It may not be necessary to update the IC software (they are only speculations).
