Pave´s 2011 Polo 6R 1.2TSI 105HP Highline DSG
Re: Pave´s 2011 Polo 6R 1.2TSI 105HP Highline DSG
Yes, check your email. :wink:
Pave
Drives: 1.2 Tsi Highline 2011
Post by Pave »
Little more modifications since last post...
Got windows lightly tinted... pictures coming :)
Started to install BCM Max and OEM Xenon headlights... let´s see when those are finished :)
Updating pictures from that procedure later too :)
BCM coding sent.... :)
Pave
Post by Pave »
Here is few quick (and not good at all :) ) pictures of new mods and what I have done last few days...
Better pictures will come later :)
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 073170389
Coding: 24B02BBF08A10000003004917C2B15D05AC0472F600510C0200000030000
Shop #: WSC 12345 123 12345
VCID: 2A501830454A131197-807E
8) ... and bixenon headlights OK!!
Monday,05,June,2017,20:02:21:46394
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 17.1.3.0
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: WVWZZZ6RZBY142712   License Plate:
Mileage: 84390km-52437mi   Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 56 0B
VIN: WVWZZZ6RZBY142712   Mileage: 84390km-52437miles
Address 01: Engine (J623-CBZB)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 E    HW: 03F 906 070 D
   Component: SIMOS10.20H02 9856
   Revision: --------    Serial number:
   Coding: 002500D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070E 003013
   ROD: EV_ECM12TFS_003_VW25.rod
   VCID: 244CF6082F6EC561AD-8070
Readiness: 0010 0001
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AJ    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3417100B4842C14E382D300401300
   VCID: 06088C80B5921771D3-8052
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 387432788BE6B18111-806C
   Subsystem 1 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0903
   Serial number: KU0-KU012.10.1010856
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 0902
   Serial number: KU0-KU022.10.1012388
   Coding: 08BC30
   Subsystem 3 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
   Component: J388__TSG_HL  006 0902
   Serial number: KU0-KU027.10.1012758
   Coding: 08BC32
   Subsystem 4 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
   Component: J389__TSG_HR  006 0902
   Serial number: KU0-KU014.10.1011471
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 B    HW: 7E0 919 475
   Component: PARKHILFE 4K  H10 0012
   Revision: --------    Serial number: 12831028801597
   Coding: 108101
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3D7A236CACC494A9C2-8068
   Component: VW10Airbag01M H09 0020
   Revision: --------    Serial number: 003GX009NX3Y
   Coding: 00314D
   VCID: 4A9078B0ED0A331177-801E
   Serial number: 3575HRB405N085G248T7
   Serial number: 3585HRB405P085G2AP9D
   Serial number: 3515RRB405B036N2A8P4
   Serial number: 3525RRB405B036N2H16T
   Part No SW: 6R0 920 860 F    HW: 6R0 920 860 F
   Component: KOMBI         H04 0304
   Coding: 140E00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
   VCID: 377631448EF8BEF918-8062
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 002200
   VCID: 68D4A2389BC6E10141-803C
   Component: IMMO          H04 0304
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6AD0D8308DCAD31157-803E
   Part No: 6R0 423 156 B
   Coding: 11220
   Shop #: WSC 00788
   VCID: 2F660924EAA8763940-807A
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 5M0 035 186 J    HW: 5M0 035 186 J
   Component: RCD310 EU T   H06 5007
   Revision: -----10S    Serial number: VWZ4Z2P1327206
   Coding: 05000400020001
   Shop #: WSC 02754 790 12345
   VCID: 336E0554928052D924-8066
1 Fault Found:
00856 - Radio Antenna
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 6
                    Reset counter: 1
                    Mileage: 83087 km
                    Time Indication: 0
                    Date: 2011.09.22
                    Time: 13:29:21
End-------------------------(Elapsed Time: 02:46)--------------------------
viewtopic.php?f=56&t=69826#p520855
Pave
Post by Pave »
... and everyone knows to whom all thanks will go :)
Pave
Post by Pave »
Some pictures of what I was doing last days...
Some polishing and coating...
Tiny steps towards Auto-levelling system (AFS) :)
Rear badge modifying...
Further modification for rims... removing vinyl wrappings and replaced with gunmetal rubber coating...
Pave
Post by Pave »
Maybe pictures are now working... :?
Yes, now they work. 8)
Pave
Post by Pave »
Changed foglights to those with black surrounds and housing and without place for drl (6R0941061F, 6R0941062F) .... because drl´s are now somewehere else :D
New one on left, old one on right
that picture also doesn't work ;)
Pave
Post by Pave »
:? What!!
Source of the pictures is same as all other pictures.... I can´t use these things...
I think it´s something to do if I make collection of pictures what I want to update...
Sorry... try to fix that :(
spacewalker
Drives: Just a VW
Post by spacewalker »
just to want to see your new cluster , but cant ;(
Pave
Post by Pave »
Updated full auto scan to first page.... especially fo ciclo! :D
Here is some new mods:
Gti cluster finally
Last parts of the AFS
Newer version of pedal caps and now also footrest
Pave
Post by Pave »
spacewalker wrote: Sat Jul 15, 2017 11:42 am just to want to see your new cluster , but cant ;(
Now it is there... I hope
Big thanks to you again for making to have that new cluster possible!!
I think my phone died and there are more pictures... will upload more when I can.
