Hello, ive just found this forum specifically for this issue, i dont know if i should be worried or not but here it is:
Ive just made a healight bulb replacement, no screws touched, the one thing i disconnected from the old bulb was its power and reconnected it to the new one, put the key in the ignition to test it, everything seems to work just fine except i noticed a continuous beeeeeeeeeeeep sound coming from literally the area of the headlight or somewhere very close, the only thing i imagine i may have done wrong was possible having the bulb the wrong way around "possitive/negative" ends, but then wouldnt it not light up ? Any thoughts ?
Continuous sound under the hood
Re: Continuous sound under the hood
That’s the headlight adjust motor making a noise. Is it there with the engine running?
