Cross Polo 6R Upgrading to BCM Max with Auto light switch
MaDwArLoCk
Drives: Cross Polo 2010 TSI
Re: Cross Polo 6R Upgrading to BCM Max with Auto light switch
Post by MaDwArLoCk »
Nope, relay not clicking... :(
MaDwArLoCk wrote: Tue Aug 15, 2017 9:05 pm
https://postimg.org/image/vy9smst7d/
Check wiring for headlight relay (assuming you have BCM Max and auto light wiring in the car).
Climatronic faults... hmm... basic setting?, bad electrical installation?.
Maybe benji58 or iichel can help you fix it. They also swapped from A/C or Climatic to Climatronic.
0B must be there.
61-Battery Regul. Software bug (7H0 BCM 7L6) for your 6R, which is 7L3.
In my topic (in some part of it) there are some comments that we made of this for a 6R from Portugal.
I do not know if this mate from Portugal was able to solve it.
As for lights:
1- Test with this BCM coding and tell me the results (Autoscan).
24B02BBF48E3240093300FB02CEB1ED01BC0610E60042001200000010000
2- Test with this BCM coding and tell me the results (2nd AutoScan)
24B02BBF48E3240093300FB02CEB1ED01BC0610E60042000200000030000
The meaning of these BCM codings is so that I know what is going on, so posting the faults that appear in VCDS autoscans is the most important thing. Two autoscan.
Rear fog lamp
signal: from T10/7 to T73b/43
output power: from T73a/6 to fog lamp. In your case, also through the fuse 18 if you did as indicated in the installation guide, so the fuse 18 must be installed.
Solving the HVAC error should be easy :-)
https://www.mypolo.nl/xenforo/threads/i ... ost-173452
MaDwArLoCk
Here are all connections i've made:
Isolated:
T17/3, T17/6, T17/7
T6/3
T73A/45
WL0
SB49b (30A) - SB57a (15A)
WL2
T73B/68 - SB39b (15A)
T73A/63 - SB59b (15A)
T73A/2 - (orig.) sb39b
T73B/2 - (orig.) sb59b
T73A/62 - SB34b + (orig.) 34b
T73b/11 - SB57b
(bridge to J331 relay)
WL3
T73B/1 - T6/3
T73B/43 - T10/7
T73A/6 - T17/9
T73B/7 - T17/16
T73A/45 - T10/3
T73B/29 - T10/9
WL5
T10/1 - T17/11
T10/2 - T73A/37
T10/3 - T73A/45
T10/4 - T17/1
T10/5 - To Fog Lights Relay (3)
T10/6 - T17/10 - To relay HL (5) - To Relay FL (5)
T10/7 - T73B/43
T10/8 - T17/15 - To Relay Headlights (1)
T10/9 - T73B/29
T10/10 - T17/17
Headlights Relay
(1) - T17/15 - T10/8
(2) - T7/4
(3) - T73A/1
(5) - To Reley FL (5) - T17/10 - T10/6
Foglights Relay
(1) - T17/2
(2) - T17/8
(3) - T10/5
(5) - To Reley HL (5) - T17/10 - T10/6
I will try new coding now...
MaDwArLoCk
iichel wrote: Mon Aug 21, 2017 7:54 am Solving the HVAC error should be easy :-)
I saw your solution already!
Unfortunately it doesn't work for me.. :( :( :(
MaDwArLoCk
ciclo wrote: Mon Aug 21, 2017 7:29 am
As for lights:
BCM have no faults!
Dimmer working.
High beam and Rear fog light - not working
Monday,21,August,2017,10:33:39:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 17.1.3.0
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: WVWZZZ6RZAU000000   License Plate:
Chassis Type: 6R (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 37 44 56 77 0B
VIN: WVWZZZ6RZAU000000   Mileage: 156960km-97530miles
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
Address 01: Engine (J623-CBZB)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 D    HW: 03F 906 070 D
   Component: SIMOS10.20H02 9851
   Revision: --------    Serial number:
   Coding: 001900D6202400080000
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_ECM12TSF02103F906070D 003015
   ROD: N/A
   VCID: 234234CE2A4EB859D4-8076
No ASAM data for: "EV_ECM12TSF02103F906070D" (VW25)
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AF    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0005
   Revision: --------
   Coding: 210228E3227300BA842C14E844D600401300
   Shop #: WSC 31414 790 31414
   VCID: 020C514A99945151FF-8056
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 3878F3A28BC8CB8111-806C
2 Faults Found:
00457 - Control Module for Network (J519)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 11
                    Mileage: 156965 km
                    Time Indication: 0
                    Date: 2012.01.12
                    Time: 00:40:17
            013 - Check DTC Memory - Intermittent
                    Fault Status: 00101101
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 51
                    Mileage: 156965 km
                    Time Indication: 0
                    Date: 2012.01.12
                    Time: 00:40:17
Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 090 B    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0712
   Revision: B9074001    Serial number: 0571 017140713
   Coding: 24B02BBF48E3240093300FB02CEB1ED01BC0610E60042001200000010000
   Shop #: WSC 02756 790 00000
   VCID: 2D56D2F6748A7E2972-8078
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 210310 05  54  0403
   Coding: 06302D
   Subsystem 2 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0903
   Serial number: KU0-KU028.04.1013935
   Coding: 18BC30
   Subsystem 3 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 0902
   Serial number: KU0-KU030.04.1010613
   Coding: 08BC30
   Subsystem 5 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HO  H11 9004
   Subsystem 7 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
   Component: J388__TSG_HL  006 0902
   Serial number: KU0-KU026.04.1016866
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
   Component: J389__TSG_HR  006 0902
   Serial number: KU0-KU020.04.1013618
   Coding: 08BC32
MaDwArLoCk
As for lights:
Dimmer does not work
High beam and rear fog lamo does not work
Monday,21,August,2017,10:45:49:39744
www.Ross-Tech.com
   ASAM Dataset: EV_ECM1T2FS02103F906070D 003015
   ROD: N/A
No ASAM data for: "EV_ECM1T2FS02103F906070D" (VW25)
   Revision: --------
   Revision: V0000000
2 Faults Found:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 11
                    Mileage: 156965 km
                    Time Indication: 0
                    Date: 2012.01.12
                    Time: 00:40:17
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 11
                    Mileage: 156965 km
                    Time Indication: 0
                    Date: 2012.01.12
                    Time: 00:40:17
   Coding: 24B02BBF48E3240093300FB02CEB1ED01BC0610E60042000200000030000
   Coding: 06302D
   Coding: 18BC30
   Coding: 08BC30
   Coding: 08BC32
   Coding: 08BC32
1 Fault Found:
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 52
                    Mileage: 156965 km
                    Time Indication: 0
                    Date: 2012.01.12
                    Time: 13:24:48
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 A    HW: 7E0 919 475
   Component: PARKHILFE 4K  H10 0011
   Revision: --------    Serial number: 64531012301615
   Coding: 100003
   ASAM Dataset: EV_VW250ParkiAsiss2 S01008
   ROD: N/A
   VCID: 3C70EFB2B7F0E7A1F5-8068
No ASAM data for: "EV_VW250ParkiAsiss2" (VW25)
   Component: VW10Airbag00K H08 0020
   Revision: --------    Serial number: 003GX002F4VI
   Coding: 00304B
   VCID: 4A9CB96AED24491177-801E
   Serial number: 3572SRB40000B53459C7
   Serial number: 3582SRB40000B520C0C1
   Serial number: 3515RRB405D6QGG0HO90
   Serial number: 3525RRB405B6SD5OFPMN
   Part No SW: 6R0 920 860 D    HW: 6R0 920 860 D
   Component: KOMBI         H03 0207
   Coding: 140800
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
   VCID: 3566FA9694DA36E90A-8060
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H74 0712
   Revision: B9074001
   Coding: 002200
   VCID: 70E80B82A33853C119-8024
   Component: IMMO          H03 0207
   Serial number:
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Imm_oUDS_VDD_RM09 A03006
   ROD: N/A
   VCID: 6ADC19EA8DE4A91157-803E
No ASAM data for: "EV_Imm_oUDS_VDD_RM09" (VW36 *)
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 R    HW: 1T0 035 680 R
   Component: RNS-MID       H21 6270
   Revision: AB001001    Serial number: VWZ6Z7N8319084
   Coding: 040104020100002C0001
   Shop #: WSC 01357 011 00200
   VCID: 3D76E2B6A4EAEEA9C2-8068
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V14  8477
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 31414
   VCID: 2F6AC8FEEA860C3940-807A
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 D    HW: 7P6 035 730 D
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668399469
   Coding: 0A00000000010110
   Shop #: WSC 05314 115 12345
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 3362C48E9AAE28D924-8066
End-------------------------(Elapsed Time: 03:45)--------------------------
ciclo wrote: Mon Aug 21, 2017 7:29 am Rear fog lamp
I did not made anything with fuse 18. (it wasnt mentioned in the istallation guide) But i have it in my fuse box (5A)
Perfect!. Let me check a few things ...
I'll tell you something later.
MaDwArLoCk wrote: Mon Aug 21, 2017 9:13 am Here are all connections i've made:
Isolated:
T17/3, T17/6, T17/7
T6/3
T73A/45
WL0
WL2
T73b/11 - SB57b
WL3
T73B/1 - T6/3
T73B/43 - T10/7
T73A/6 - T17/9
T73B/7 - T17/16
T73A/45 - T10/3
T73B/29 - T10/9
WL5
T10/1 - T17/11
T10/2 - T73A/37
T10/3 - T73A/45
T10/4 - T17/1
T10/7 - T73B/43
T10/9 - T73B/29
T10/10 - T17/17
Headlights Relay
(2) - T7/4 ....(T17/4) :lol:
(3) - T73A/1
Foglights Relay
(1) - T17/2
(2) - T17/8
(3) - T10/5
All these connections are correct.
Next thing to do:
Test with this BCM coding.
24B02BBF48E3240093300FB02CEB1ED011C0610E60042001200000010000
Depending on the results we will know what happens with the high beam and rear fog lamp. (I guess)
Note: For the results of previous BCM codings, some diagnostics are missing.
I could explain it, but it is something complex and it is not necessary for you (besides that my English is far from being correct). Everything depends on the evolution in the BCM software 7H0 and 7E0, and on the other hand on VCDS software (labels).
MaDwArLoCk
ciclo wrote: Mon Aug 21, 2017 11:34 am
Still doesn't work
may be it's something wrong with High beam relay connection? its not clicking.. Fog lights relay - OK
High beam works only in "blink" mode.
Monday,21,August,2017,13:12:49:39744
www.Ross-Tech.com
VIN: WVWZZZ6RZAU00000   License Plate:
   ASAM Dataset: EV_EMC12TFS02103F906070D 003015
   ROD: N/A
No ASAM data for: "EV_EMC12TFS02103F906070D" (VW25)
   Revision: --------
   Revision: V0000000
2 Faults Found:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 12
                    Mileage: 156965 km
                    Time Indication: 0
                    Date: 2012.01.12
                    Time: 00:40:17
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 52
                    Mileage: 156965 km
                    Time Indication: 0
                    Date: 2012.01.12
                    Time: 00:40:17
   Coding: 24B02BBF48E3240093300FB02CEB1ED011C0610E60042001200000010000
   Coding: 06302D
   Coding: 18BC30
   Coding: 08BC30
   Coding: 08BC32
   Coding: 08BC32
   Coding: 100003
   ASAM Dataset: EV_VW250PrakiAssis2 S01008
   ROD: N/A
No ASAM data for: "EV_VW250PrakiAssis2" (VW25)
   Coding: 00304B
   ASAM Dataset: EV_AirbaVW10BAPVW250 A01001
   ROD: N/A
   Subsystem 1 - Serial number: 3572SRB40000B53459C7
   Subsystem 2 - Serial number: 3582SRB40000B520C0C1
   Subsystem 3 - Serial number: 3515RRB405D6QGG0HO90
   Subsystem 4 - Serial number: 3525RRB405B6SD5OFPMN
No ASAM data for: "EV_AirbaVW10BAPVW250" (VW25)
   Coding: 140800
   Revision: B9074001
   Coding: 002200
Some diagnostics are missing because I have Chinese VCDS
And pretty often it show error about "license"..
I need three or four attempts to make full autoscan.
MaDwArLoCk wrote: Mon Aug 21, 2017 12:14 pm Still doesn't work
... Fog lights relay - OK
Therefore, the connections are correct from the SB34b (fuse) to the headlights.
Therefore ... exchange the relay to find out if the relay is faulty (you have at least one more, or use fog lights relay. :wink: ).
Also check that the 0.5mm thin wire from SB34b to T73a/62 is correctly installed.
BCM coding:
MaDwArLoCk
ciclo wrote: Mon Aug 21, 2017 1:19 pm
I have tried it already, same story!
ciclo wrote: Mon Aug 21, 2017 1:19 pm BCM coding:
I am at work now, So I could check this coding only tomorrow morning...
MaDwArLoCk
By the way, at firegrafik's post on Drive2, he wrote:
Питание (15 клемма) с контакта Т17/1 идет на реле откуда при включении реле по команде от ВСМ с контакта Т73а/1 возвращается к проводу с контакта Т17/4 где уже идет на подрулевой переключатель по штатной схеме.
He took power for headlights relay from T17/1 instead of T17/15.
May be I should try?
MaDwArLoCk wrote: Mon Aug 21, 2017 2:23 pm
...or better this:
24B02BBF48E3240093300EB02CEB1ED01BC0610E60042001200000010000
MaDwArLoCk wrote: Mon Aug 21, 2017 3:11 pm By the way, at firegrafik's post on Drive2, he wrote:
NO
Byte18 Bit5 is the culprit.
It must manage your High beam in all light switch positions when installed automatic lights, must be enabled.
The real problem is that we know absolutely nothing about the BCM you bought. As for example, what was the donor car and its specs...
99% of the problems in these mods are due to the purchase of used parts (cheaped) without the correct identification. (Damn experience :))
Sometimes it is possible to solve them. ...sometimes.
There is an endless list of BCM Max (7H0 and 7E0) and the data (PR-codes) provided by ETKA are limited, or they are missing.
If you had bought a BCM 7E0937090C, we would all be happier right now. :lol:
Precisely, you can speak with firegrafik to help you with this purchase if you want.
