1.4 engine removal tools/hoist
littlepolo
Do I need a crane/hoist to remove and replace a 1.4 engine and transmission?
Re: 1.4 engine removal tools/hoist
Yes. Absolutely no way you’ll get it out otherwise
littlepolo
Thanks.
When I take the engine/auto trans out are there any bolts/fasteners that will need to be replaced other than:
Wheel hub nuts
Engine mount bolts
Wheel hub nuts
Engine mount bolts
It’s not a straight out job. I strongly suggest you get a Haynes manual which documents the process in great detail
You could swap it on a jack if you take the front end off (assuming your polo has a bolt on front end)
