UPGRADING BCM 6R
Re: UPGRADING BCM 6R
Run a wire from Fuse 57 on fuse holder B to BCM T73b/11 (1mm2 of thickness)
Run a wire from BCM T73b/10 to the left fog light, 1.5mm2 of thickness, the other wire of the fog light to a ground point
Run a wire from BCM T73b/9 to the right fog light, 1.5mm2 of thickness, the other wire of the fog light to a ground point
Run a wire from light switch T17/8 to BCM T73a/7, thickness 1.5mm2
Do you have a steering angle sensor? (i.e. ESP from factory)?
govindsharma
- Drives: polo 1.2 petrol HighLine
I have steering angle in my car not factory installed installed with the help of by Ciclo Sir.
Thank you.
Thank you.
govindsharma
I had purchased following wireiichel wrote: Sun Sep 03, 2017 3:27 pm Run a wire from Fuse 57 on fuse holder B to BCM T73b/11 (1mm2 of thickness)
VW Polo 6R + 6C cable harness daytime running TFL over Bordsteuergerä t
- ag69
- Drives: 1.2TSi 77Kw 7DSG
A question related to wiring here. Apologies for taking thread to different discussion.iichel wrote: Sun Sep 03, 2017 3:27 pm Run a wire from Fuse 57 on fuse holder B to BCM T73b/11 (1mm2 of thickness)
But is there any guidelines document/reference for which wire ie thickness should be used for which connection?
- 1.0 mm(square)
- 1.5 mm(square)
- 2.0 mm(square)
- Any other specifications
Yes, this is all specified in the wiring diagrams, i.e. in ElsaWIN or ERWIN
- ag69
Thanks iichel.
I think here are couple of links for newbe like me:
http://www.erwin-portal.com/
http://wiki.ross-tech.com/wiki/index.ph ... nformation
https://erwin.vw.com/erwin/showOrderFlatrate.do
How can one use it:
How can one use it:
antardaksh04
- Drives: TSI
Hi,govindsharma wrote: Sun Sep 03, 2017 5:57 pm I had purchased following wire
Following diagram (by Ciclo) might also be useful to wire DRL. You might have already seen this , I thought I will share for benefit of others.
Regards.
He's talking about daytime lights, not fog lights.iichel wrote: Sun Sep 03, 2017 3:27 pm Run a wire from Fuse 57 on fuse holder B to BCM T73b/11 (1mm2 of thickness)
Hmm it's possible, maybe, you need vacation ... my vacation ended
viewtopic.php?f=56&t=69603&start=45#p524154govindsharma wrote: Sun Sep 03, 2017 2:58 pm Dear Sir I had purchased fog lights with static cornering lights and day time running lights 6C0941661 and 6C0941662. Now tell me in which bcm connector wire must be connected and coding for it.
Thank you
https://ibb.co/c1aVwv
The gray/purple wire in the diagram that goes to T73b / 29 is already installed in your 6R, included in the wiring you bought me
T73a/5 ... Black connector ... Right DRL
T73b/3 ... White connector ... Left DRL
govindsharma
Good Morning Dear
Can you please tell me what coding i have to do in BCM for making fog lights with DRLs works.
Thank you.
Thank you.
Sure, tell me your current BCM coding.
govindsharma
My Car Current BCM coding is as follows.Now tell me coding for fog lights with DRLs.
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 352161207
Coding: 3AB02BBF48A3000001380FB07CEB9E901BC0614F60AC2000200000030800
Shop #: WSC 12345 123 12345
VCID: 2A5B68CE453E0312DE-807E
Thank you.
Thank you.
DRL over cornering lights:
3AB02BBF48A3000001380FB07CEB9E901BC0614F60AC2044200000030800
1 New BCM coding (copy-paste)govindsharma wrote: Tue Oct 10, 2017 1:30 pm My Car Current BCM coding is as follows.Now tell me coding for fog lights with DRLs.
Thank you.
3AB02BBF48A3000001380FB06CEB9E905FC0616F60AC2040200000030800
2 If you also want
3AB02BBF48A3000001380FB06CEB9E905FC0616F60AC20C0200000030800
3 If you also want
3AB02BBF48A3000001380FB06CEB9E905FC0616F60AC20D0200000030800
... and everything will work perfectly in your 6R with your new installation (fog lights with additional bulbs for DRLs).
Do the options 2 and 3 also work with halogen DRL? If I understood correctly, the bi-xenon headlights are not installed.
